Good Day all,
I have a thermostat that I have moved from Smartthings to hassio via the Aotec Stick. I can control it fine, and I am using the Dual card no issues at all, but what I am curious about it that is shows up in Google Home as four entities. Is there a way to combine it to one entity in google so when I say okay… set downstairs temp to 72 it knows… the same thing for heat… but under one item in google. Hopefully, that makes sense.
The Entities are as follows
Climate.cooling_1
Climate.cooling_econ
Climate.heating_1
Climate.heating_econ
I will never use Econ, no way to get rid of it so only using Heat/Cool_1 for the dual temp card.
