Setup:
- Home Assistant 0.99.3 running in Docker on RasPi 4B
- Razberry Z-Wave Hat (Model 5 I believe)
- TKB Home TZ77 RGBW LED Strip Controller
Problem:
Light strip appearing as 5 separate channels in HA GUI. I believe this should just be one standard ‘color picker’ GUI.
Details:
I added the LED Controller to a new setup (this is the first thing I’m adding) and it successfully appeared as a node under ZWave Config. The node appears to have 5 Entities, all with an Unknown name. A bit of playing around shows that 4 of these correspond to dimming R,G,B & W and the final one acts as an overall dimmer but also seems to attempt to act as a full colour control but somehow gets the color completely wrong.
Attempted Fixes:
- I found this discussion about creating a fake MQTT Light to solve the problem, but other than this seeming like a hack, since I don’t have an MQTT broker to begin with I wasn’t sure this would work anyway.
- I found this doc on openhab https://github.com/openhab/org.openhab.binding.zwave/blob/bea7de6d78d5610a129150e2b9c90714967c7a02/doc/tkb/tz77_0_0.md which shows that there should actually be 6 channels. I also found this github issue which showed that the Colour channel was initially not working https://community.openhab.org/t/tkb-tz77-database-correction/64779
I am completely new to HA, but happy to get stuck in with a fix, even if it means a pull request. Any help greatly appreciated!
Node Info:
node id
4
node name
TKB Home Unknown: type=0311, id=0302
manufacturer name
TKB Home
product name
query stage
Complete
is awake
true
is ready
true
is failed
false
is info received
true
max baud rate
40000
is zwave plus
true
capabilities
routing, listening, beaming, zwave_plus
neighbors
1, 2
sentCnt
237
sentFailed
0
retries
1
receivedCnt
260
receivedDups
1
receivedUnsolicited
84
sentTS
2019-10-07 21:23:06:383
receivedTS
2019-10-07 21:23:11:732
lastRequestRTT
24
averageRequestRTT
24
lastResponseRTT
30
averageResponseRTT
31
application version
2.12
