I flipped a breaker in the house to work with electrical and now my z-wave is completely non functional. I have tried restores, reboots, restarting the modem and router. I have no idea what is causing this.
Logger: homeassistant.components.hassio.handler
Source: components/hassio/handler.py:596
Integration: Home Assistant Supervisor (documentation, issues)
First occurred: 12:32:02 AM (1 occurrences)
Last logged: 12:32:02 AM
Timeout on /addons/core_zwave_js/start request
Logger: homeassistant.components.zwave_js
Source: components/hassio/addon_manager.py:380
Integration: Z-Wave (documentation, issues)
Failed to start the Z-Wave JS add-on:
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/config.sh
[00:43:42] INFO: No 'network_key' detected, setting it to 's0_legacy_key' for backwards compatibility
[00:43:44] INFO: Flushing config to disk due to creation of new key(s)...
[00:43:45] INFO: Soft-reset set to automatic
[00:43:45] INFO: Virtual Machine not detected, enabling soft-reset
cont-init: info: /etc/cont-init.d/config.sh exited 0
cont-init: info: running /etc/cont-init.d/structure.sh
cont-init: info: /etc/cont-init.d/structure.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun zwave_js (no readiness notification)
s6-rc: info: service legacy-services successfully started
[00:43:48] INFO: Successfully send discovery information to Home Assistant.
SyntaxError: /usr/src/node_modules/mime-db/db.json: Unexpected token in JSON at position 65
at parse (<anonymous>)
at Object.Module._extensions..json (node:internal/modules/cjs/loader:1324:39)
at Module.load (node:internal/modules/cjs/loader:1119:32)
at Function.Module._load (node:internal/modules/cjs/loader:960:12)
at Module.require (node:internal/modules/cjs/loader:1143:19)
at require (node:internal/modules/cjs/helpers:119:18)
at Object.<anonymous> (/usr/src/node_modules/mime-db/index.js:12:18)
at Module._compile (node:internal/modules/cjs/loader:1256:14)
at Object.Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
[05:43:50] WARNING: Halt add-on
s6-rc: info: service legacy-services: stopping
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
Any idea on what can be causing this?
