My Z-Wave stick moved to a different /dev/tty port after plugging in another USB device. In the old days, the configuration was in the configuration file, where is it kept now? As in, where can I change it?
Found it in core.config_entires
You can stop this from being an issue by using the “permanent” device name. It’s in /dev/serial/by-id/some_long_name_here_of_your_device
That path will always be the same for that device and will not change across reboots unplug/plug or additional usb devices.
I am also looking for the USB configuration for the Z-wave integration.
As far as I know it was configurable from the integration page itself. But I can’t find it anymore?
Does anyone know where it went? (I don’t mean the file “core.config_entries”)
Hmmm, not there in the UI, you may have to go into core.config, or re-add the integration.
