I have a question about controlling a ceiling fan.
In the bedroom we have a ceiling fan with 3 ventilation speed modes, dimmable lamp and remote control. The fan is connected to a normal wall switch.
Using wall switch:
- Switching off ensures that lamp and fan go out (remote control no longer works)
- By switching on 2x in succession (on/off/on) I can switch the lamp on again. The fan remains off and can be turned on again with the remote control.
Soon we will have our new house and I want to improve this. I have already found the following:
- By changing the wires, light and fan can be switched separately from each other
- The type of fan motor is not suitable for controlling with a fibaro dimmer
Now I wonder if the following setup is possible:
- Wiring light and fan separated
- Fan always live, without wall switch. Operation only via remote control
- Control (dimmable) light via several Wall switches with fibaro (or comparable) modules
- Lighting then probably no longer via remote control
I hope my description is clear enough. I’m curious if this is possible.
