Z-Wave with Pi 4
I am running Pi 4 the beta version. I am new and want to start with Z-Wave. I read the I need to buy a USB stick.
Could you please explain me which usb stick to buy:
https://www.z-wave.com/search-products?utf8=✓&query=z-wave+stick
Whare the components that I need to start? I bought a wall switch that support z-wave.
Thank you
As mentioned in the HA docs the Aeotec stick has been reported as not working on the Pi4.
Of the rest of the items on the list, I’d personally suggest the ZWave.me stick if it supports your region, but any Z-Wave Plus stick will work. They all use the same chipset.
Well you CAN get it to work via a USB2.0 hub.
Ditto, get the cheapest nastiest USB2.0 hub you can find and it works fine.
@Tinkerer
Thank you for your advice. Is this the USB?
That’s the UZB, yes.
Just letting you know I have found a Pi 4 working z wave stick
