I could install the Raspberry Pi All-In-One Installer on my Raspberry 3 as described on https://github.com/home-assistant/fabric-home-assistant or https://home-assistant.io/getting-started/installation-raspberry-pi-all-in-one/
I could start the openzwave Control panel with “sudo ./ozwcp -p 8888”.
My USB-Zwave stick was found on /dev/ttyACM0 and I could add the first light actor.
But on my home-assistant webinterface http://:8123 I’m not able to connect to the USB-ZWave.
Which one should be the path to zwave with Raspberry all-in-one installer?
configuration.yaml:
zwave:
usb_path: /dev/ttyACM0
config_path: /srv/hass/src/open-zwave-control-panel/
polling_interval: 60000
customize:
sensor.kitchen.light1:
polling_intensity: 1
cat /home/hass/home-assistant.log:
16-05-30 16:17:23 homeassistant.bootstrap: Error during setup of component zwave
File “/srv/hass/hass_venv/lib/python3.4/site-packages/openzwave-0.3.1-py3.4.egg/openzwave/option.py”, line 72, in init
raise ZWaveException(u"Can’t find device %s : %s" % (device, traceback.format_exception(*sys.exc_info())))
File “/usr/lib/python3.4/traceback.py”, line 181, in format_exception
return list(_format_exception_iter(etype, value, tb, limit, chain))
File “/usr/lib/python3.4/traceback.py”, line 146, in _format_exception_iter
for value, tb in values:
File “/usr/lib/python3.4/traceback.py”, line 125, in _iter_chain
context = exc.context
AttributeError: ‘NoneType’ object has no attribute ‘context’
File “/srv/hass/hass_venv/lib/python3.4/site-packages/homeassistant/bootstrap.py”, line 157, in _setup_component
if not component.setup(hass, config):
