[Z-Wave][Zigbee] Set temporary guest code for door lock
I recently purchases a Zigbee smart door lock with programmable codes, and wanted to make a script that can set a temporary “guest” code for a set duration (automatically delete the code after an amount of time)
I made two blueprints, one for Zigbee devices (which I’ve personally confirmed works with my lock) and one for Z-Wave devices (untested). They both do the same thing:
  • Sets a code
  • Optionally triggers another action, such as notify
  • Waits for an amount of time to pass
  • Deletes the code
  • Optional triggers another action, such as notify
Scripts
Zigbee (requires ZHA Toolkit)
# This script uses ZHA Toolkit (https://github.com/mdeweerd/zha-toolkit) to manage smart door lock codes, and therefore ZHA Toolkit needs to be installed.
# There is no gaurantee that this script will work as expected with your particular ZigBee smart door lock.
# This has been tested against a Kwikset SmartCode 916 (https://www.kwikset.com/products/detail/916-smartcode-traditional-electronic-deadbolt-with-zigbee-technology)
blueprint:
  name: Set Guest Door Code (ZigBee)
  description: >-
    A script that sets a temporary code for a ZigBee smart door lock (via ZHA Toolkit).
    This script adds and removes a new code, rather than enabling/disabling an existing code.
  source_url: https://raw.githubusercontent.com/nwithan8/configs/main/home_assistant/blueprints/scripts/set_guest_door_code_zigbee.yaml
  domain: script
  input:
    lock:
      description: (Required) Which door lock to program
      selector:
          entity:
            domain: lock
    slot:
      description: (Required) Which code slot to use
      selector:
        text:
    on_start:
      description: (Optional) Action to execute when code is enabled
        The lock entity is available via the "lock" variable.
        The set code is available via the "code" variable.
        The set code slot is available via the "slot" variable.
        The validity time is available via the "duration" variable.
      name: When code enabled
      default: []
      selector:
    on_end:
      description: (Optional) Action to execute when code is disabled
      name: When code disabled
      default: []
      selector:
fields:
  code:
    description: The code to set
    example: "1234"
    required: true
    selector:
      text: null
  duration:
    description: How long the code is valid for
    required: true
    selector:
      duration:
        enable_day: true
variables:
  lock: !input lock
  slot: !input slot
sequence:
  - service: zha.set_lock_user_code
      code_slot: "{{ slot }}"
      user_code: "{{ code }}"
      entity_id: "{{ lock.entity_id }}"
  - choose:
      - conditions: "{{ true }}"
        sequence: !input on_start
  - delay: "{{ duration }}"
  - service: zha.clear_lock_user_code
  - choose:
        sequence: !input on_end
mode: single
Z-Wave (requires Keymaster)
# This script uses Keymaster (https://github.com/FutureTense/keymaster) to manage smart door lock codes, and therefore Keymaster needs to be installed.
# There is no gaurantee that this script will work as expected with your particular Z-Wave smart door lock.
blueprint:
  name: Set Guest Door Code (Z-Wave)
  description: >-
    A script that sets a temporary code for a Z-Wave smart door lock (via Keymaster).
  source_url: https://raw.githubusercontent.com/nwithan8/configs/main/home_assistant/blueprints/scripts/set_guest_door_code_zwave.yaml
  domain: script
  input:
    lock:
      selector:
          entity:
            domain: lock
    slot:
      selector:
        text:
    on_start:
      description: (Optional) Action to execute when code is enabled.
      default: []
      selector:
    on_end:
      description: (Optional) Action to execute when code is disabled.
      default: []
      selector:
fields:
  code:
    example: "1234"
    required: true
    selector:
      text: null
  duration:
    required: true
    selector:
      duration:
        enable_day: true
variables:
  lock: !input lock
  slot: !input slot
sequence:
  - service: keymaster.add_code
      usercode: "{{ code }}"
  - choose:
  - service: keymaster.clear_code
  - choose:
mode: single
Usage
Setting up the script
This script will set code slot 30 on the Front Door Lock to whatever code is provided.
After enabling the code, a notification will be sent to my phone, telling me what code was just set.
When the provided time is lapsed, the code will be deleted, and a notification will be sent to my phone to confirm.
Although they are optional, I would recommend using the “When code enabled” and “When code disabled” actions to trigger some sort of notification or other action to confirm that the code has been added and removed. Alternatively, you could use these actions to trigger other automations or scripts, such as disabling a house alarm or preparing for a guest’s arrival.
Calling the script
This will set the guest code to “1234” for 12 hours, after which it will be deleted.
Hi Nate, how could I adapt this for the Aqara U100? Note for that particular lock currently you need to lair it over zigbee to matter enabled m2 hub which can then be used to bring in the lock via matter to HA.
Hmm, I would imagine the pin code setting capabalities probably got lost in the Zigbee-to-Matter translation. I assume you’ve already sanity-check tried to use this script (or just the zha.set_locker_user_code service directly) to modify the code on your door lock?
Hi @nwithan8. Can I adapt this blueprint for the Z-Wave Allegion SBE469ZP without Keymaster? I’ll share the results here.
Go for it.
Thank you. It works on Allegion SBE469ZP.
# This script uses ZWaveJS HA Integration to manage smart door lock codes.
# This has been tested on Allegion SBE469ZP (https://www.schlage.com/en/home/products/BE469ZPCAMFFF.html)
blueprint:
  description: >-
    A script that sets a temporary code for a Z-Wave smart door lock (via ZWaveJS).
  source_url: https://community.home-assistant.io/c/blueprints-exchange
  domain: script
  input:
    lock:
      selector:
          entity:
            domain: lock
    slot:
      selector:
        text:
    on_start:
      default: []
      selector:
    on_end:
      default: []
      selector:
fields:
  code:
    example: "123456"
    required: true
    selector:
      text: null
  duration:
    required: true
    selector:
      duration:
        enable_day: true
variables:
  lock: !input lock
  slot: !input slot
sequence:
  - service: zwave_js.set_lock_usercode
  - choose:
  - service: zwave_js.clear_lock_usercode
  - choose:
mode: single
@nwithan8 I justed started using Home Assistant (Yellow) and have a few devices setup. I installed a Kwikset 916 (zigbee) and your blueprint works great. I was wondering how to find out what commands are available for the lock within the ZHA Toolkit. I have tried scan device and a few others with no results. Could you point in the right direction to get a list of commands? Thanks
Helllo guys, I have zigbee kiwikset and tried to add it to my zigbee network. but it states not supported.
Battery is about 70%, Appreciate if you can advise me if any other setting need to be activated. TIA
Hi Nate. What other slots other than “30” can I use? I tried 31-36 but they don’t seem to work for me.
Slots 1-30 should be available. This defaults to using Slot 30, the last slot on the device.
