I did not do that, but I made some progress. I toggled the “priveleged” setting on docker to on based ona
youtube comment and it ended up recognizing the path and I was able to add the integration. Now I’m stuck at “Starting Z-Wave Network”. Here’s the log:
2020-06-02 02:40:28.475 Always, OpenZwave Version 1.4.3469 Starting Up
2020-06-02 02:40:38.599 Info, Setting Up Provided Network Key for Secure Communications
2020-06-02 02:40:38.599 Info, mgr, Added driver for controller /dev/ttyUSB1
2020-06-02 02:40:38.600 Info, Opening controller /dev/ttyUSB1
2020-06-02 02:40:38.600 Info, Trying to open serial port /dev/ttyUSB1 (attempt 1)
2020-06-02 02:40:38.601 Info, Serial port /dev/ttyUSB1 opened (attempt 1)
2020-06-02 02:40:38.601 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2020-06-02 02:40:38.601 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2020-06-02 02:40:38.601 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2020-06-02 02:40:38.601 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2020-06-02 02:40:38.601 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2020-06-02 02:40:38.601 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x15) - FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2020-06-02 02:40:39.601 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-06-02 02:40:39.601 Detail, contrlr, Removing current message
2020-06-02 02:40:39.601 Detail, contrlr, Notification: Notification - TimeOut
2020-06-02 02:40:39.602 Detail,
2020-06-02 02:40:39.602 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x20) - FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2020-06-02 02:40:40.602 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-06-02 02:40:40.602 Detail, contrlr, Removing current message
2020-06-02 02:40:40.602 Detail, contrlr, Notification: Notification - TimeOut
2020-06-02 02:40:40.603 Detail,
2020-06-02 02:40:40.603 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x05) - FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2020-06-02 02:40:41.603 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-06-02 02:40:41.603 Detail, contrlr, Removing current message
2020-06-02 02:40:41.603 Detail, contrlr, Notification: Notification - TimeOut
2020-06-02 02:40:41.604 Detail,
2020-06-02 02:40:41.604 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x07) - FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2020-06-02 02:40:42.604 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-06-02 02:40:42.604 Detail, contrlr, Removing current message
2020-06-02 02:40:42.604 Detail, contrlr, Notification: Notification - TimeOut
2020-06-02 02:40:42.605 Detail,
2020-06-02 02:40:42.605 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x56) - FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2020-06-02 02:40:43.605 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-06-02 02:40:43.605 Detail, contrlr, Removing current message
2020-06-02 02:40:43.605 Detail, contrlr, Notification: Notification - TimeOut
