Hi, I have quite a few vision zd2102eu-5 laying around (from an old smart home installation that doesn’t exist anymore)
I managed to exclude a few of them and am now trying to get them to be included in my home assistant os set-up.
I am new to Z-wave, but got zwave-js integration with zwavejs2mqtt installed.
Then I got zwavejs2mqtt to include the door/window sensor, but it doesn’t seem to be complete. It also gets back to sleep after 10seconds even after manually waking it up which may have something to do with it…
I have been trying to do this, but it goes to sleep after 10sec each time, after which I have to push the tampet switch for a few seconds before I can wake it up again for another 10…
At least that is the only way I found to get it awake, maybe I am missing something. I will try it a couple of times more.
Do I have to push reinterview or will it continue when the device wakes up?
Is there no way to manually input some identification etc. to facilitate the process?
That sounds like the right wake up method for that device.The interview usually continues on its own. If it’s not doing anything within that 10 seconds, sounds like something is not working correctly. I’d monitor the driver logs to see if it’s actually communicating with the driver when it wakes.
Well, I have tried to keep the device awake during breakfast this morning, but that didn’t seem to have much effect.
I may try again tonight or exclude and include again or something…
I enabled ‘silly’ logging, but at first glance I don’t immediately know where to start.
I do get the following message a lot:
2022-03-06T23:00:12.182Z DRIVER RangeError: The value of "offset" is out of range. It must be >= 0 and <= 14.
Received 15
at new NodeError (node:internal/errors:371:5)
at boundsError (node:internal/buffer:86:9)
at Buffer.readInt8 (node:internal/buffer:424:5)
at parseRSSI (/opt/node_modules/zwave-js/src/lib/controller/SendDataShared
.ts:91:22)
at new BridgeApplicationCommandRequest (/opt/node_modules/zwave-js/src/lib
/controller/BridgeApplicationCommandRequest.ts:81:24)
at Function.from (/opt/node_modules/zwave-js/src/lib/message/Message.ts:22
8:15)
at Driver.serialport_onData (/opt/node_modules/zwave-js/src/lib/driver/Dri
ver.ts:2135:18)
at SerialAPIParser.emit (node:events:520:28)
at SerialAPIParser.emit (node:domain:475:12)
at addChunk (node:internal/streams/readable:315:12)
Thanks I will try that.
I am using version 0.35.2
Meanwhile, no success with the door sensor, I may have to give up and find another solution… But not yet
I got a pretty quick reply on the zwave-js github.
The above error should already be fixed in the current version (8.11.9).
However, my home assistant os seems to still be on 8.11.6, I guess there is no way to update that one to 8.11.9 myself?
