Importing Blueprints into Home Assistant
If you see this import badge, click it:
To import a Blueprint manually:
- Visit the topic of the blueprint that you want to import
- Copy the URL from the browser address bar
- Go to Home Assistant → Configuration → Automations & Scenes → Blueprints and click on “Import Blueprint” button in the bottom right.
- Paste the blueprint topic URL and click on “Preview Blueprint”
- Click on “Import Blueprint”
blueprint:
name: Ikea E2123 - Z2M 2.0 - Generic use
description: >-
This blueprint is for Ikea E2123 generic use.
domain: automation
input:
remote:
description: The MQTT device created by Z2M
selector:
device:
filter:
- integration: mqtt
play_pause: #firmware 1.0.35
name: Play Button Click
description: Action to perform (firmware 1.0.35)
selector:
default: []
toggle: #firmware 1.0.32
description: Action to perform (firmware 1.0.32)
selector:
default: []
track_next:
name: Next track Button Click
selector:
default: []
track_previous:
name: Previous track click
selector:
default: []
volume_up:
name: Volume up click
selector:
default: []
volume_up_hold:
name: Volume up click hold
selector:
default: []
volume_down:
name: Volume down click
selector:
default: []
volume_down_hold:
name: Volume down click hold
selector:
default: []
dots_1_initial_press:
name: Dots 1 click
selector:
default: []
dots_1_short_release:
name: Dots 1 click short release
selector:
default: []
dots_1_double_press:
name: Dots 1 double press
selector:
default: []
dots_1_long_press:
name: Dots 1 long press
selector:
default: []
dots_1_long_release:
name: Dots 1 long release
selector:
default: []
dots_2_initial_press:
name: Dots 2 click
selector:
default: []
dots_2_short_release:
name: Dots 2 click short release
selector:
default: []
dots_2_double_press:
name: Dots 2 double press
selector:
default: []
dots_2_long_press:
name: Dots 2 long press
selector:
default: []
dots_2_long_release:
name: Dots 2 long release
selector:
default: []
mode: parallel
max: 10
triggers:
- domain: mqtt
device_id: !input remote
type: action
subtype: play_pause
trigger: device
- domain: mqtt
type: action
subtype: toggle
trigger: device
- domain: mqtt
type: action
subtype: track_next
trigger: device
- domain: mqtt
type: action
subtype: track_next
trigger: device
- domain: mqtt
type: action
subtype: volume_up
trigger: device
- domain: mqtt
type: action
subtype: volume_up_hold
trigger: device
- domain: mqtt
type: action
subtype: volume_down
trigger: device
- domain: mqtt
type: action
subtype: volume_down_hold
trigger: device
- domain: mqtt
type: action
subtype: dots_1_initial_press
trigger: device
- domain: mqtt
type: action
subtype: dots_1_short_release
trigger: device
- domain: mqtt
type: action
subtype: dots_1_double_press
trigger: device
- domain: mqtt
type: action
subtype: dots_1_long_release
trigger: device
- domain: mqtt
type: action
subtype: dots_2_initial_press
trigger: device
- domain: mqtt
type: action
subtype: dots_2_short_release
trigger: device
- domain: mqtt
type: action
subtype: dots_2_double_press
trigger: device
- domain: mqtt
type: action
subtype: dots_2_long_press
trigger: device
- domain: mqtt
type: action
subtype: dots_2_long_release
trigger: device
conditions: []
actions:
- choose:
- conditions:
- condition: trigger
id:
- play_pause
sequence: !input play_pause
- choose:
- conditions:
id:
- toggle
sequence: !input toggle
- conditions:
id:
- track_next
sequence: !input track_next
- conditions:
id:
- track_previous
sequence: !input track_previous
- conditions:
id:
- volume_up
sequence: !input volume_up
- conditions:
id:
- volume_up_hold
sequence: !input volume_up_hold
- conditions:
id:
- volume_down
sequence: !input volume_down
- conditions:
id:
- volume_down_hold
sequence: !input volume_down_hold
- conditions:
id:
- dots_1_initial_press
sequence: !input dots_1_initial_press
- conditions:
id:
- dots_1_short_release
sequence: !input dots_1_short_release
- conditions:
id:
- dots_1_double_press
sequence: !input dots_1_double_press
- conditions:
id:
- dots_1_long_press
sequence: !input dots_1_long_press
- conditions:
id:
- dots_1_long_release
sequence: !input dots_1_long_release
- conditions:
id:
- dots_2_initial_press
sequence: !input dots_2_initial_press
- conditions:
id:
- dots_2_short_release
sequence: !input dots_2_short_release
- conditions:
id:
- dots_2_double_press
sequence: !input dots_2_double_press
- conditions:
id:
- dots_2_long_press
sequence: !input dots_2_long_press
- conditions:
id:
- dots_2_long_release
sequence: !input dots_2_long_release
