Heyhey
I got about 25 frient smoke detectors and use them with z2m.
All of those devices are working perfectly fine, but when startin z2m I receive the following error for all of them:
[2024-12-03 08:18:58] error: z2m: Failed to configure 'Feuermelder Laden 1', attempt 1 (Error: Bind 0x0015bc003101c6ce/35 genBinaryInput from '0x8c65a3fffe54d71f/1' failed (Status 'TABLE_FULL')
at Endpoint.bind (/app/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:566:23)
at Object.bind (/app/node_modules/zigbee-herdsman-converters/src/lib/reporting.ts:42:9)
at configure (/app/node_modules/zigbee-herdsman-converters/src/devices/develco.ts:406:13)
at Object.configure (/app/node_modules/zigbee-herdsman-converters/src/index.ts:205:21)
at Configure.configure (/app/lib/extension/configure.ts:130:13)
This happens three times for every smoke detector.
So attempt1, attempt2, and attempt3. Allo f them fail with the exact same error code.
Ive been using many different firmwares (oldest form 2021) and upgraded all of them - via z2m - to the newest.
But this didnt change anything.
Is this a problem with the devices itself - or something I just can ignore as mentioned the devices are working perfectly fine.
Or is this some misconfiguration of mine?
Im using z2m Home Assistant addon version 1.41.0-1.
The error appeared (atleast) in the last two z2m versions also.
I added a screenshot with my z2m configuration.
The entered baudrate and the rtsctc. false are newly added.
Im using Sonoff Dongle E with firmware 7.4.4.0. But here I also tried 7.4.3.0 and 7.4.2.0 and some 7.3.x.x. versions
