Z2M - Aqara Opple - 2 Button
Here is a fork of the 4 button blueprint to use on my own Hassio that uses the 2 button Opple switch via Zigbee2mqtt.
Tested OK this evening :slight_smile:
blueprint:
  name: Z2M - Aqara Opple - Wireless Scene Switch 2 Button
  description: Control anything using Aqara Opple two button remote
  domain: automation
  input:
    switch:
      description: Aqara switch to use
      selector:
        entity:
          domain: sensor
          integration: mqtt
    button_left_single_press:
      name: Left button - Single press
      description: Action to run on a single press of the left button
      default: []
      selector:
        action: {}
    button_left_double_press:
      name: Left button - Double press
      description: Action to run on a double press of the left button
      default: []
      selector:
        action: {}
    button_left_triple_press:
      name: Left button - Triple press
      description: Action to run on a triple press of the left button
      default: []
      selector:
        action: {}
    button_left_hold:
      name: Left button - Hold
      description: Action to run when left button is held
      default: []
      selector:
        action: {}
    button_right_single_press:
      name: Right button - Single press
      description: Action to run on a single press of the right button
      default: []
      selector:
        action: {}
    button_right_double_press:
      name: Right button - Double press
      description: Action to run on a double press of the right button
      default: []
      selector:
        action: {}
    button_right_triple_press:
      name: Right button - Triple press
      description: Action to run on a triple press of the right button
      default: []
      selector:
        action: {}
    button_right_hold:
      name: Right button - Hold
      description: Action to run when right button is held
      default: []
      selector:
        action: {}
mode: single
max_exceeded: silent
- platform: state
  entity_id: !input 'switch'
  attribute: action
- variables:
    command: '{{ trigger.to_state.state }}'
- choose:
  - conditions:
    - '{{ command == ''button_1_single'' }}'
    sequence: !input 'button_left_single_press'
  - conditions:
    - '{{ command == ''button_1_double'' }}'
    sequence: !input 'button_left_double_press'
  - conditions:
    - '{{ command == ''button_1_triple'' }}'
    sequence: !input 'button_left_triple_press'
  - conditions:
    - '{{ command == ''button_1_hold'' }}'
    sequence: !input 'button_left_hold'
  - conditions:
    - '{{ command == ''button_2_single'' }}'
    sequence: !input 'button_right_single_press'
  - conditions:
    - '{{ command == ''button_2_double'' }}'
    sequence: !input 'button_right_double_press'
  - conditions:
    - '{{ command == ''button_2_triple'' }}'
    sequence: !input 'button_right_triple_press'
  - conditions:
    - '{{ command == ''button_2_hold'' }}'
    sequence: !input 'button_right_hold'
If you know how to filter more the selector, I would be happy to enhance this blueprint !
Have a nice day/evening.
Fred.
