Z2M - Aqara Wireless mini switch with any click option
I have created a blueprint for the Aqara Wireless mini switch using Zigbee2MQTT (Z2M).
The blueprint includes a Any click option to respond to any type of click.
blueprint:
  name: Z2M - Aqara Wireless mini switch (any, single, double, triple, quadruple, hold, release)
  description: Control anything you want with Aqara Wireless mini Switch.
  author: TheBigNeo
  domain: automation
  input:
    device_selection:
      name: Select the device you want to configure
      description: Aqara switch to use
      selector:
        device:
          filter:
            - integration: mqtt
              model: Wireless mini switch
          multiple: false
    button_any:
      description: Action to run on any click
      default: [ ]
      selector:
        action: { }
    button_single:
      description: Action to run on single click
      default: [ ]
      selector:
        action: { }
    button_double:
      description: Action to run on double click
      default: [ ]
      selector:
        action: { }
    button_triple:
      description: Action to run on triple click
      default: [ ]
      selector:
        action: { }
    button_quadruple:
      description: Action to run on quadruple click
      default: [ ]
      selector:
        action: { }
    button_hold:
      description: Action to run on hold
      default: [ ]
      selector:
        action: { }
    button_release:
      description: Action to run after hold then release
      default: [ ]
      selector:
        action: { }
mode: queued
max_exceeded: silent
  - domain: mqtt
    device_id: !input device_selection
    type: action
    subtype: single
    trigger: device
  - domain: mqtt
    type: action
    subtype: double
    trigger: device
  - domain: mqtt
    type: action
    subtype: triple
    trigger: device
  - domain: mqtt
    type: action
    subtype: quadruple
    trigger: device
  - domain: mqtt
    type: action
    subtype: hold
    trigger: device
  - domain: mqtt
    type: action
    subtype: release
    trigger: device
  - sequence: !input button_any
  - choose:
      - conditions:
          - condition: template
            value_template: '{{ trigger.payload == ''single'' }}'
        sequence: !input button_single
      - conditions:
            value_template: '{{ trigger.payload == ''double'' }}'
        sequence: !input button_double
      - conditions:
            value_template: '{{ trigger.payload == ''triple'' }}'
        sequence: !input button_triple
      - conditions:
            value_template: '{{ trigger.payload == ''hold'' }}'
        sequence: !input button_hold
      - conditions:
            value_template: '{{ trigger.payload == ''release'' }}'
        sequence: !input button_release
