Thank you for answering me.
HA and Z2M up-to-date.
Sonos player is the one added through official integration. Nothing Custom
No other automation interfering.
Here are some screenshots of Trace and feedbacks from MQTT or Z2M
And logs :
Some warning, but no errors Could one of them be the issue ?
Supervisor.log
23-11-22 17:08:52 WARNING (MainThread) [supervisor.addons.options] Option 'dark_mode' does not exist in the schema for Node-RED (a0d7b954_nodered)
23-11-22 17:08:52 WARNING (MainThread) [supervisor.addons.options] Option 'require_ssl' does not exist in the schema for Node-RED (a0d7b954_nodered)
23-11-22 17:08:52 WARNING (MainThread) [supervisor.addons.options] Unknown option 'logins' for Mosquitto broker (core_mosquitto)
23-11-22 17:08:52 WARNING (MainThread) [supervisor.addons.options] Unknown option 'base_topic' for Zigbee2MQTT (45df7312_zigbee2mqtt)
23-11-22 17:08:52 WARNING (MainThread) [supervisor.addons.options] Option 'advanced' does not exist in the schema for Zigbee2MQTT (45df7312_zigbee2mqtt)
23-11-22 17:11:34 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
23-11-22 17:13:52 WARNING (MainThread) [supervisor.addons.options] Option 'dark_mode' does not exist in the schema for Node-RED (a0d7b954_nodered)
23-11-22 17:13:52 WARNING (MainThread) [supervisor.addons.options] Option 'require_ssl' does not exist in the schema for Node-RED (a0d7b954_nodered)
23-11-22 17:13:52 WARNING (MainThread) [supervisor.addons.options] Unknown option 'logins' for Mosquitto broker (core_mosquitto)
23-11-22 17:13:52 WARNING (MainThread) [supervisor.addons.options] Unknown option 'base_topic' for Zigbee2MQTT (45df7312_zigbee2mqtt)
23-11-22 17:13:52 WARNING (MainThread) [supervisor.addons.options] Option 'advanced' does not exist in the schema for Zigbee2MQTT (45df7312_zigbee2mqtt)
Mosquito Broker. What are those ?
2023-11-22 17:10:48: New connection from xxx.xx.x.x:33644 on port 1883.
2023-11-22 17:10:48: Client <unknown> closed its connection.
2023-11-22 17:12:48: New connection from xxx.xx.x.x:33722 on port 1883.
2023-11-22 17:12:48: Client <unknown> closed its connection.
2023-11-22 17:14:48: New connection from xxx.xx.x.x:33832 on port 1883.
2023-11-22 17:14:48: Client <unknown> closed its connection.
Z2M
Zigbee2MQTT:info 2023-11-22 17:00:32: MQTT publish: topic 'zigbee2mqtt/0x84ba20fffe512487', payload '{"action":"play_pause","battery":null,"linkquality":255,"update":{"installed_version":16777269,"latest_version":16777269,"state":"idle"},"update_available":false,"voltage":2900}'
Zigbee2MQTT:info 2023-11-22 17:00:32: MQTT publish: topic 'zigbee2mqtt/0x84ba20fffe512487', payload '{"action":"","battery":null,"linkquality":255,"update":{"installed_version":16777269,"latest_version":16777269,"state":"idle"},"update_available":false,"voltage":2900}'
Zigbee2MQTT:info 2023-11-22 17:00:32: MQTT publish: topic 'zigbee2mqtt/0x84ba20fffe512487/action', payload 'play_pause'
Zigbee2MQTT:info 2023-11-22 17:00:44: MQTT publish: topic 'zigbee2mqtt/0x84ba20fffe512487', payload '{"action":"play_pause","battery":null,"linkquality":255,"update":{"installed_version":16777269,"latest_version":16777269,"state":"idle"},"update_available":false,"voltage":2900}'
Zigbee2MQTT:info 2023-11-22 17:00:44: MQTT publish: topic 'zigbee2mqtt/0x84ba20fffe512487', payload '{"action":"","battery":null,"linkquality":255,"update":{"installed_version":16777269,"latest_version":16777269,"state":"idle"},"update_available":false,"voltage":2900}'
Zigbee2MQTT:info 2023-11-22 17:00:44: MQTT publish: topic 'zigbee2mqtt/0x84ba20fffe512487/action', payload 'play_pause'
Zigbee2MQTT:info 2023-11-22 17:02:12: MQTT publish: topic 'zigbee2mqtt/0x84ba20fffe512487', payload '{"action":"play_pause","battery":null,"linkquality":152,"update":{"installed_version":16777269,"latest_version":16777269,"state":"idle"},"update_available":false,"voltage":2900}'
Zigbee2MQTT:info 2023-11-22 17:02:12: MQTT publish: topic 'zigbee2mqtt/0x84ba20fffe512487', payload '{"action":"","battery":null,"linkquality":152,"update":{"installed_version":16777269,"latest_version":16777269,"state":"idle"},"update_available":false,"voltage":2900}'
Zigbee2MQTT:info 2023-11-22 17:02:12: MQTT publish: topic 'zigbee2mqtt/0x84ba20fffe512487/action', payload 'play_pause'
Zigbee2MQTT:info 2023-11-22 17:03:28: MQTT publish: topic 'zigbee2mqtt/0x84ba20fffe512487', payload '{"action":"play_pause","battery":null,"linkquality":255,"update":{"installed_version":16777269,"latest_version":16777269,"state":"idle"},"update_available":false,"voltage":2900}'
Zigbee2MQTT:info 2023-11-22 17:03:28: MQTT publish: topic 'zigbee2mqtt/0x84ba20fffe512487', payload '{"action":"","battery":null,"linkquality":255,"update":{"installed_version":16777269,"latest_version":16777269,"state":"idle"},"update_available":false,"voltage":2900}'
Zigbee2MQTT:info 2023-11-22 17:03:28: MQTT publish: topic 'zigbee2mqtt/0x84ba20fffe512487/action', payload 'play_pause'
