Updated to the latest Z-Stack_3.x.0 CC1352P_2_20200417 and after this I can’t send commands with payloads. All sensors report fine and I can see the data in the log, but if I try to press a button to turn on a light, I get following error message:
zigbee2mqtt:error 28-05-2020 00:12:33: Publish 'set' 'state' to 'Hue Sofa' failed: 'Error: Command 0x0017880104d303a8/11 genOnOff.on({}, {"timeout":10000,"manufacturerCode":null,"disableDefaultResponse":false}) failed (Error: Timeout - 2165 - 11 - 8 - 6 - 11 after 10000ms)'
zigbee2mqtt:info 28-05-2020 00:12:33: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"type":"zigbee_publish_error","message":"Publish 'set' 'state' to 'Hue Sofa' failed: 'Error: Command 0x0017880104d303a8/11 genOnOff.on({}, {\"timeout\":10000,\"manufacturerCode\":null,\"disableDefaultResponse\":false}) failed (Error: Timeout - 2165 - 11 - 8 - 6 - 11 after 10000ms)'","meta":{"friendly_name":"Hue Sofa"}}'
Anybody tested this new firmware, and/or have a quick solution? Soft-reset, reboot, unplug didn’t resolve it…
