Z2M - device joining and leaving
Just bought 2 new devices but both I cannot pair…
I have tried many things, rebooting, restarting, restting… nothing works.
My setup is:
HAOS
Z2M app/addon: Zigbee2MQTT Current version: 2.9.1-1
SLZB-06M
Model: SLZB-06M
Radio Core
Status: On-board On-board
Flow control: SW -
CPU model: EFR32MG21 ESP32-S3
CPU cores and clock: 1 @ 80 MHz 2 @ 240 MHz
Flash memory: 768 KB 16Mb
RAM memory: 96 KB 520Kb
SoC temperature: 31.67 °C 35.56 °C
Firmware version: 20250220 v3.2.4
Latest FW check: Unknown 14/03/2026
This is the error. I have 2 of these devices and both I cannot pair.
[3/14/2026, 9:16:03 PM] z2m:mqtt: MQTT publish: topic ‘zigbee2mqtt/0xffffb40e0605a3bd/availability’, payload ‘{“state”:“online”}’
[3/14/2026, 9:16:03 PM] zh:controller: Interview for ‘0xffffb40e0605a3bd’ started
[3/14/2026, 9:16:03 PM] z2m: Device ‘0xffffb40e0605a3bd’ joined
[3/14/2026, 9:16:04 PM] z2m: Starting interview of ‘0xffffb40e0605a3bd’
[3/14/2026, 9:16:04 PM] z2m:mqtt: MQTT publish: topic ‘zigbee2mqtt/bridge/event’, payload ‘{“data”:{“friendly_name”:“0xffffb40e0605a3bd”,“ieee_address”:“0xffffb40e0605a3bd”},“type”:“device_joined”}’
[3/14/2026, 9:16:04 PM] z2m:mqtt: MQTT publish: topic ‘zigbee2mqtt/bridge/event’, payload ‘{“data”:{“friendly_name”:“0xffffb40e0605a3bd”,“ieee_address”:“0xffffb40e0605a3bd”,“status”:“started”},“type”:“device_interview”}’
[3/14/2026, 9:16:04 PM] zh:controller:device: Device ‘0xffffb40e0605a3bd’ is only compliant to revision ‘21’ of the Zigbee specification (current revision: 23).
[3/14/2026, 9:16:09 PM] zh:controller: Succesfully interviewed ‘0xffffb40e0605a3bd’
[3/14/2026, 9:16:09 PM] z2m: Successfully interviewed ‘0xffffb40e0605a3bd’, device has successfully been paired
[3/14/2026, 9:16:09 PM] z2m: Device ‘0xffffb40e0605a3bd’ is supported, identified as: Third Reality Smart Soil Moisture Sensor (3RSM0147Z)
[3/14/2026, 9:16:09 PM] z2m: Configuring ‘0xffffb40e0605a3bd’
[3/14/2026, 9:16:09 PM] z2m:mqtt: MQTT publish: topic ‘homeassistant/sensor/0xffffb40e0605a3bd/temperature/config’, payload ‘{“availability”:[{“topic”:“zigbee2mqtt/bridge/state”,“value_template”:“{{ value_json.state }}”},{“topic”:“zigbee2mqtt/0xffffb40e0605a3bd/availability”,“value_template”:“{{ value_json.state }}”}],“availability_mode”:“all”,“default_entity_id”:“sensor.0xffffb40e0605a3bd_temperature”,“device”:{“hw_version”:0,“identifiers”:[“zigbee2mqtt_0xffffb40e0605a3bd”],“manufacturer”:“Third Reality”,“model”:“Smart Soil Moisture Sensor”,“model_id”:“3RSM0147Z”,“name”:“0xffffb40e0605a3bd”,“sw_version”:“v1.00.38”,“via_device”:“zigbee2mqtt_bridge_0x00124b0029dc07c5”},“device_class”:“temperature”,“enabled_by_default”:true,“object_id”:“0xffffb40e0605a3bd_temperature”,“origin”:{“name”:“Zigbee2MQTT”,“sw”:“2.9.1”,“url”:“https://www.zigbee2mqtt.io”},“state_class”:“measurement”,“state_topic”:“zigbee2mqtt/0xffffb40e0605a3bd”,“unique_id”:“0xffffb40e0605a3bd_temperature_zigbee2mqtt”,“unit_of_measurement”:“°C”,“value_template”:“{{ value_json.temperature }}”}’
[3/14/2026, 9:16:09 PM] z2m:mqtt: MQTT publish: topic ‘zigbee2mqtt/bridge/event’, payload ‘{“data”:{“definition”:{“description”:“Smart Soil Moisture Sensor”,“exposes”:[{“access”:5,“description”:“Measured temperature value”,“label”:“Temperature”,“name”:“temperature”,“property”:“temperature”,“type”:“numeric”,“unit”:“°C”},{“access”:5,“description”:“Measured soil moisture value”,“label”:“Soil moisture”,“name”:“soil_moisture”,“property”:“soil_moisture”,“type”:“numeric”,“unit”:“%”},{“access”:5,“category”:“diagnostic”,“description”:“Remaining battery in %”,“label”:“Battery”,“name”:“battery”,“property”:“battery”,“type”:“numeric”,“unit”:“%”,“value_max”:100,“value_min”:0},{“access”:1,“category”:“diagnostic”,“description”:“Link quality (signal strength)”,“label”:“Linkquality”,“name”:“linkquality”,“property”:“linkquality”,“type”:“numeric”,“unit”:“lqi”,“value_max”:255,“value_min”:0}],“model”:“3RSM0147Z”,“options”:[{“access”:2,“description”:“Calibrates the temperature value (absolute offset), takes into effect on next report of device.”,“label”:“Temperature calibration”,“name”:“temperature_calibration”,“property”:“temperature_calibration”,“type”:“numeric”,“value_step”:0.1},{“access”:2,“description”:“Number of digits after decimal point for temperature, takes into effect on next report of device. This option can only decrease the precision, not increase it.”,“label”:“Temperature precision”,“name”:“temperature_precision”,“property”:“temperature_precision”,“type”:“numeric”,“value_max”:3,“value_min”:0},{“access”:2,“description”:“Calibrates the soil_moisture value (absolute offset), takes into effect on next report of device.”,“label”:“Soil moisture calibration”,“name”:“soil_moisture_calibration”,“property”:“soil_moisture_calibration”,“type”:“numeric”,“value_step”:0.1},{“access”:2,“description”:“Number of digits after decimal point for soil_moisture, takes into effect on next report of device. This option can only decrease the precision, not increase it.”,“label”:“Soil moisture precision”,“name”:“soil_moisture_precision”,“property”:“soil_moisture_precision”,“type”:“numeric”,“value_max”:3,“value_min”:0}],“source”:“native”,“supports_ota”:true,“vendor”:“Third Reality”},“friendly_name”:“0xffffb40e0605a3bd”,“ieee_address”:“0xffffb40e0605a3bd”,“status”:“successful”,“supported”:true},“type”:“device_interview”}’
[3/14/2026, 9:16:09 PM] z2m:mqtt: MQTT publish: topic ‘homeassistant/sensor/0xffffb40e0605a3bd/soil_moisture/config’, payload ‘{“availability”:[{“topic”:“zigbee2mqtt/bridge/state”,“value_template”:“{{ value_json.state }}”},{“topic”:“zigbee2mqtt/0xffffb40e0605a3bd/availability”,“value_template”:“{{ value_json.state }}”}],“availability_mode”:“all”,“default_entity_id”:“sensor.0xffffb40e0605a3bd_soil_moisture”,“device”:{“hw_version”:0,“identifiers”:[“zigbee2mqtt_0xffffb40e0605a3bd”],“manufacturer”:“Third Reality”,“model”:“Smart Soil Moisture Sensor”,“model_id”:“3RSM0147Z”,“name”:“0xffffb40e0605a3bd”,“sw_version”:“v1.00.38”,“via_device”:“zigbee2mqtt_bridge_0x00124b0029dc07c5”},“device_class”:“moisture”,“enabled_by_default”:true,“object_id”:“0xffffb40e0605a3bd_soil_moisture”,“origin”:{“name”:“Zigbee2MQTT”,“sw”:“2.9.1”,“url”:“https://www.zigbee2mqtt.io”},“state_class”:“measurement”,“state_topic”:“zigbee2mqtt/0xffffb40e0605a3bd”,“unique_id”:“0xffffb40e0605a3bd_soil_moisture_zigbee2mqtt”,“unit_of_measurement”:“%”,“value_template”:“{{ value_json.soil_moisture }}”}’
[3/14/2026, 9:16:09 PM] z2m:mqtt: MQTT publish: topic ‘homeassistant/sensor/0xffffb40e0605a3bd/battery/config’, payload ‘{“availability”:[{“topic”:“zigbee2mqtt/bridge/state”,“value_template”:“{{ value_json.state }}”},{“topic”:“zigbee2mqtt/0xffffb40e0605a3bd/availability”,“value_template”:“{{ value_json.state }}”}],“availability_mode”:“all”,“default_entity_id”:“sensor.0xffffb40e0605a3bd_battery”,“device”:{“hw_version”:0,“identifiers”:[“zigbee2mqtt_0xffffb40e0605a3bd”],“manufacturer”:“Third Reality”,“model”:“Smart Soil Moisture Sensor”,“model_id”:“3RSM0147Z”,“name”:“0xffffb40e0605a3bd”,“sw_version”:“v1.00.38”,“via_device”:“zigbee2mqtt_bridge_0x00124b0029dc07c5”},“device_class”:“battery”,“enabled_by_default”:true,“entity_category”:“diagnostic”,“object_id”:“0xffffb40e0605a3bd_battery”,“origin”:{“name”:“Zigbee2MQTT”,“sw”:“2.9.1”,“url”:“https://www.zigbee2mqtt.io”},“state_class”:“measurement”,“state_topic”:“zigbee2mqtt/0xffffb40e0605a3bd”,“unique_id”:“0xffffb40e0605a3bd_battery_zigbee2mqtt”,“unit_of_measurement”:“%”,“value_template”:“{{ value_json.battery }}”}’
[3/14/2026, 9:16:09 PM] z2m:mqtt: MQTT publish: topic ‘homeassistant/sensor/0xffffb40e0605a3bd/linkquality/config’, payload ‘{“availability”:[{“topic”:“zigbee2mqtt/bridge/state”,“value_template”:“{{ value_json.state }}”},{“topic”:“zigbee2mqtt/0xffffb40e0605a3bd/availability”,“value_template”:“{{ value_json.state }}”}],“availability_mode”:“all”,“default_entity_id”:“sensor.0xffffb40e0605a3bd_linkquality”,“device”:{“hw_version”:0,“identifiers”:[“zigbee2mqtt_0xffffb40e0605a3bd”],“manufacturer”:“Third Reality”,“model”:“Smart Soil Moisture Sensor”,“model_id”:“3RSM0147Z”,“name”:“0xffffb40e0605a3bd”,“sw_version”:“v1.00.38”,“via_device”:“zigbee2mqtt_bridge_0x00124b0029dc07c5”},“enabled_by_default”:false,“entity_category”:“diagnostic”,“icon”:“mdi:signal”,“name”:“Linkquality”,“object_id”:“0xffffb40e0605a3bd_linkquality”,“origin”:{“name”:“Zigbee2MQTT”,“sw”:“2.9.1”,“url”:“https://www.zigbee2mqtt.io”},“state_class”:“measurement”,“state_topic”:“zigbee2mqtt/0xffffb40e0605a3bd”,“unique_id”:“0xffffb40e0605a3bd_linkquality_zigbee2mqtt”,“unit_of_measurement”:“lqi”,“value_template”:“{{ value_json.linkquality }}”}’
[3/14/2026, 9:16:09 PM] z2m:mqtt: MQTT publish: topic ‘homeassistant/update/0xffffb40e0605a3bd/update/config’, payload ‘{“availability”:[{“topic”:“zigbee2mqtt/bridge/state”,“value_template”:“{{ value_json.state }}”},{“topic”:“zigbee2mqtt/0xffffb40e0605a3bd/availability”,“value_template”:“{{ value_json.state }}”}],“availability_mode”:“all”,“command_topic”:“zigbee2mqtt/bridge/request/device/ota_update/update”,“default_entity_id”:“update.0xffffb40e0605a3bd”,“device”:{“hw_version”:0,“identifiers”:[“zigbee2mqtt_0xffffb40e0605a3bd”],“manufacturer”:“Third Reality”,“model”:“Smart Soil Moisture Sensor”,“model_id”:“3RSM0147Z”,“name”:“0xffffb40e0605a3bd”,“sw_version”:“v1.00.38”,“via_device”:“zigbee2mqtt_bridge_0x00124b0029dc07c5”},“device_class”:“firmware”,“entity_category”:“config”,“entity_picture”:“https://github.com/Koenkk/zigbee2mqtt/raw/master/images/logo.png",“name”:null,“object_id”:“0xffffb40e0605a3bd”,“origin”:{“name”:“Zigbee2MQTT”,“sw”:“2.9.1”,“url”:“https://www.zigbee2mqtt.io”},“payload_install”:"{"id": "0xffffb40e0605a3bd"}”,“state_topic”:“zigbee2mqtt/0xffffb40e0605a3bd”,“unique_id”:“0xffffb40e0605a3bd_update_zigbee2mqtt”,“value_template”:“{"latest_version":"{{ value_json[‘update’][‘latest_version’] }}","installed_version":"{{ value_json[‘update’][‘installed_version’] }}","update_percentage":{{ value_json[‘update’].get(‘progress’, ‘null’) }},"in_progress":{{ (value_json[‘update’][‘state’] == ‘updating’)|lower }}}”}’
[3/14/2026, 9:16:09 PM] z2m:mqtt: MQTT publish: topic ‘zigbee2mqtt/Thermostaat_Radiator_Waskamer’, payload ‘{“battery_low”:false,“child_lock”:“UNLOCK”,“current_heating_setpoint”:21,“error”:null,“frost_protection”:null,“linkquality”:132,“local_temperature”:14,“local_temperature_calibration”:null,“pi_heating_demand”:null,“running_state”:“heat”,“scale_protection”:null,“schedule_friday”:“06:00/12.0 08:00/16.0 18:00/22.0 20:00/20.0 NaN:NaN/NaN NaN:NaN/NaN”,“schedule_monday”:“06:00/12.0 08:00/16.0 18:00/22.0 20:00/20.0 NaN:NaN/NaN NaN:NaN/NaN”,“schedule_saturday”:“06:00/12.0 08:00/16.0 18:00/22.0 20:00/20.0 NaN:NaN/NaN NaN:NaN/NaN”,“schedule_sunday”:“06:00/12.0 08:00/16.0 18:00/22.0 20:00/20.0 NaN:NaN/NaN NaN:NaN/NaN”,“schedule_thursday”:“06:00/12.0 08:00/16.0 18:00/22.0 20:00/20.0 NaN:NaN/NaN NaN:NaN/NaN”,“schedule_tuesday”:“06:00/12.0 08:00/16.0 18:00/22.0 20:00/20.0 NaN:NaN/NaN NaN:NaN/NaN”,“schedule_wednesday”:“06:00/12.0 08:00/16.0 18:00/22.0 20:00/20.0 NaN:NaN/NaN NaN:NaN/NaN”,“system_mode”:“heat”}’
[3/14/2026, 9:16:10 PM] z2m:mqtt: MQTT publish: topic ‘zigbee2mqtt/0xffffb40e0605a3bd’, payload ‘{“battery”:null,“linkquality”:200,“soil_moisture”:null,“temperature”:26.08,“update”:{“installed_version”:-1,“latest_version”:-1,“state”:null}}’
[3/14/2026, 9:16:10 PM] z2m: Failed to configure ‘0xffffb40e0605a3bd’, attempt 1 (Error: Device 0xffffb40e0605a3bd has no input cluster msSoilMoisture
at getEndpointsWithCluster (/app/node_modules/.pnpm/[email protected]/node_modules/zigbee-herdsman-converters/src/lib/modernExtend.ts:75:15)
at configure (/app/node_modules/.pnpm/[email protected]/node_modules/zigbee-herdsman-converters/src/lib/modernExtend.ts:241:29)
at Object.configure (/app/node_modules/.pnpm/[email protected]/node_modules/zigbee-herdsman-converters/src/index.ts:362:27)
at Configure.configure (/app/lib/extension/configure.ts:135:13)
at EventEmitter.wrappedCallback (/app/lib/eventBus.ts:252:17))
[3/14/2026, 9:16:25 PM] z2m: Device ‘0xffffb40e0605a3bd’ left the network
[3/14/2026, 9:16:25 PM] z2m:mqtt: MQTT publish: topic ‘zigbee2mqtt/bridge/event’, payload ‘{“data”:{“friendly_name”:“0xffffb40e0605a3bd”,“ieee_address”:“0xffffb40e0605a3bd”},“type”:“device_leave”}’
[3/14/2026, 9:16:30 PM] frontend:api:bridge: Sending {“topic”:“bridge/request/device/rename”,“payload”:{“from”:“0xffffb40e0605a3bd”,“to”:“bodem_vochtigheid_02”,“homeassistant_rename”:true,“last”:null,“transaction”:“lnjrp-5”}}
[3/14/2026, 9:16:30 PM] z2m: Request ‘zigbee2mqtt/bridge/request/device/rename’ failed with error: ‘Device ‘0xffffb40e0605a3bd’ does not exist’
[3/14/2026, 9:16:30 PM] z2m:mqtt: MQTT publish: topic ‘zigbee2mqtt/bridge/response/device/rename’, payload ‘{“data”:{},“error”:“Device ‘0xffffb40e0605a3bd’ does not exist”,“status”:“error”,“transaction”:“lnjrp-5”}’
[3/14/2026, 9:16:40 PM] zh:controller: Interview for ‘0xffffb40e0605a3bd’ started
[3/14/2026, 9:16:40 PM] z2m: Device ‘0xffffb40e0605a3bd’ joined
[3/14/2026, 9:16:40 PM] z2m: Starting interview of ‘0xffffb40e0605a3bd’
[3/14/2026, 9:16:40 PM] z2m:mqtt: MQTT publish: topic ‘zigbee2mqtt/bridge/event’, payload ‘{“data”:{“friendly_name”:“0xffffb40e0605a3bd”,“ieee_address”:“0xffffb40e0605a3bd”},“type”:“device_joined”}’
[3/14/2026, 9:16:40 PM] z2m:mqtt: MQTT publish: topic ‘zigbee2mqtt/bridge/event’, payload ‘{“data”:{“friendly_name”:“0xffffb40e0605a3bd”,“ieee_address”:“0xffffb40e0605a3bd”,“status”:“started”},“type”:“device_interview”}’
[3/14/2026, 9:16:42 PM] zh:controller: Succesfully interviewed ‘0xffffb40e0605a3bd’
[3/14/2026, 9:16:42 PM] z2m: Successfully interviewed ‘0xffffb40e0605a3bd’, device has successfully been paired
[3/14/2026, 9:16:42 PM] z2m: Device ‘0xffffb40e0605a3bd’ is supported, identified as: Third Reality Smart Soil Moisture Sensor (3RSM0147Z)
[3/14/2026, 9:16:42 PM] z2m: Configuring ‘0xffffb40e0605a3bd’
[3/14/2026, 9:16:42 PM] z2m:mqtt: MQTT publish: topic ‘zigbee2mqtt/bridge/event’, payload ‘{“data”:{“definition”:{“description”:“Smart Soil Moisture Sensor”,“exposes”:[{“access”:5,“description”:“Measured temperature value”,“label”:“Temperature”,“name”:“temperature”,“property”:“temperature”,“type”:“numeric”,“unit”:“°C”},{“access”:5,“description”:“Measured soil moisture value”,“label”:“Soil moisture”,“name”:“soil_moisture”,“property”:“soil_moisture”,“type”:“numeric”,“unit”:“%”},{“access”:5,“category”:“diagnostic”,“description”:“Remaining battery in %”,“label”:“Battery”,“name”:“battery”,“property”:“battery”,“type”:“numeric”,“unit”:“%”,“value_max”:100,“value_min”:0},{“access”:1,“category”:“diagnostic”,“description”:“Link quality (signal strength)”,“label”:“Linkquality”,“name”:“linkquality”,“property”:“linkquality”,“type”:“numeric”,“unit”:“lqi”,“value_max”:255,“value_min”:0}],“model”:“3RSM0147Z”,“options”:[{“access”:2,“description”:“Calibrates the temperature value (absolute offset), takes into effect on next report of device.”,“label”:“Temperature calibration”,“name”:“temperature_calibration”,“property”:“temperature_calibration”,“type”:“numeric”,“value_step”:0.1},{“access”:2,“description”:“Number of digits after decimal point for temperature, takes into effect on next report of device. This option can only decrease the precision, not increase it.”,“label”:“Temperature precision”,“name”:“temperature_precision”,“property”:“temperature_precision”,“type”:“numeric”,“value_max”:3,“value_min”:0},{“access”:2,“description”:“Calibrates the soil_moisture value (absolute offset), takes into effect on next report of device.”,“label”:“Soil moisture calibration”,“name”:“soil_moisture_calibration”,“property”:“soil_moisture_calibration”,“type”:“numeric”,“value_step”:0.1},{“access”:2,“description”:“Number of digits after decimal point for soil_moisture, takes into effect on next report of device. This option can only decrease the precision, not increase it.”,“label”:“Soil moisture precision”,“name”:“soil_moisture_precision”,“property”:“soil_moisture_precision”,“type”:“numeric”,“value_max”:3,“value_min”:0}],“source”:“native”,“supports_ota”:true,“vendor”:“Third Reality”},“friendly_name”:“0xffffb40e0605a3bd”,“ieee_address”:“0xffffb40e0605a3bd”,“status”:“successful”,“supported”:true},“type”:“device_interview”}’
[3/14/2026, 9:16:42 PM] z2m:mqtt: MQTT publish: topic ‘zigbee2mqtt/Thermostaat_Radiator_Waskamer’, payload ‘{“battery_low”:false,“child_lock”:“UNLOCK”,“current_heating_setpoint”:21,“error”:null,“frost_protection”:null,“linkquality”:132,“local_temperature”:14,“local_temperature_calibration”:null,“pi_heating_demand”:null,“running_state”:“heat”,“scale_protection”:null,“schedule_friday”:“06:00/12.0 08:00/16.0 18:00/22.0 20:00/20.0 NaN:NaN/NaN NaN:NaN/NaN”,“schedule_monday”:“06:00/12.0 08:00/16.0 18:00/22.0 20:00/20.0 NaN:NaN/NaN NaN:NaN/NaN”,“schedule_saturday”:“06:00/12.0 08:00/16.0 18:00/22.0 20:00/20.0 NaN:NaN/NaN NaN:NaN/NaN”,“schedule_sunday”:“06:00/12.0 08:00/16.0 18:00/22.0 20:00/20.0 NaN:NaN/NaN NaN:NaN/NaN”,“schedule_thursday”:“06:00/12.0 08:00/16.0 18:00/22.0 20:00/20.0 NaN:NaN/NaN NaN:NaN/NaN”,“schedule_tuesday”:“06:00/12.0 08:00/16.0 18:00/22.0 20:00/20.0 NaN:NaN/NaN NaN:NaN/NaN”,“schedule_wednesday”:“06:00/12.0 08:00/16.0 18:00/22.0 20:00/20.0 NaN:NaN/NaN NaN:NaN/NaN”,“system_mode”:“heat”}’
[3/14/2026, 9:16:43 PM] z2m:mqtt: MQTT publish: topic ‘zigbee2mqtt/0xffffb40e0605a3bd’, payload ‘{“battery”:100,“linkquality”:196,“soil_moisture”:null,“temperature”:26.08,“update”:{“installed_version”:-1,“latest_version”:-1,“state”:null}}’
[3/14/2026, 9:16:43 PM] z2m:mqtt: MQTT publish: topic ‘zigbee2mqtt/0xffffb40e0605a3bd’, payload ‘{“battery”:100,“linkquality”:200,“soil_moisture”:null,“temperature”:26.08,“update”:{“installed_version”:-1,“latest_version”:-1,“state”:null}}’
[3/14/2026, 9:16:43 PM] z2m: Failed to configure ‘0xffffb40e0605a3bd’, attempt 2 (Error: Device 0xffffb40e0605a3bd has no input cluster msSoilMoisture
[3/14/2026, 9:16:45 PM] z2m: Configuring ‘0xffffb40e0605a3bd’
[3/14/2026, 9:16:46 PM] z2m:mqtt: MQTT publish: topic ‘zigbee2mqtt/0xffffb40e0605a3bd’, payload ‘{“battery”:100,“linkquality”:196,“soil_moisture”:null,“temperature”:26.08,“update”:{“installed_version”:-1,“latest_version”:-1,“state”:null}}’
[3/14/2026, 9:16:46 PM] z2m: Failed to configure ‘0xffffb40e0605a3bd’, attempt 3 (Error: Device 0xffffb40e0605a3bd has no input cluster msSoilMoisture
[3/14/2026, 9:17:00 PM] z2m: Device ‘0xffffb40e0605a3bd’ left the network
[3/14/2026, 9:17:00 PM] z2m:mqtt: MQTT publish: topic ‘zigbee2mqtt/bridge/event’, payload ‘{“data”:{“friendly_name”:“0xffffb40e0605a3bd”,“ieee_address”:“0xffffb40e0605a3bd”},“type”:“device_leave”}’
[3/14/2026, 9:17:12 PM] zh:controller: Interview for ‘0xffffb40e0605a3bd’ started
[3/14/2026, 9:17:12 PM] z2m: Device ‘0xffffb40e0605a3bd’ joined
[3/14/2026, 9:17:12 PM] z2m: Starting interview of ‘0xffffb40e0605a3bd’
[3/14/2026, 9:17:12 PM] z2m:mqtt: MQTT publish: topic ‘zigbee2mqtt/bridge/event’, payload ‘{“data”:{“friendly_name”:“0xffffb40e0605a3bd”,“ieee_address”:“0xffffb40e0605a3bd”},“type”:“device_joined”}’
[3/14/2026, 9:17:12 PM] z2m:mqtt: MQTT publish: topic ‘zigbee2mqtt/bridge/event’, payload ‘{“data”:{“friendly_name”:“0xffffb40e0605a3bd”,“ieee_address”:“0xffffb40e0605a3bd”,“status”:“started”},“type”:“device_interview”}’
[3/14/2026, 9:17:13 PM] z2m:mqtt: MQTT publish: topic ‘zigbee2mqtt/Thermostaat_Radiator_Waskamer’, payload ‘{“battery_low”:false,“child_lock”:“UNLOCK”,“current_heating_setpoint”:21,“error”:null,“frost_protection”:null,“linkquality”:132,“local_temperature”:14,“local_temperature_calibration”:null,“pi_heating_demand”:null,“running_state”:“heat”,“scale_protection”:null,“schedule_friday”:“06:00/12.0 08:00/16.0 18:00/22.0 20:00/20.0 NaN:NaN/NaN NaN:NaN/NaN”,“schedule_monday”:“06:00/12.0 08:00/16.0 18:00/22.0 20:00/20.0 NaN:NaN/NaN NaN:NaN/NaN”,“schedule_saturday”:“06:00/12.0 08:00/16.0 18:00/22.0 20:00/20.0 NaN:NaN/NaN NaN:NaN/NaN”,“schedule_sunday”:“06:00/12.0 08:00/16.0 18:00/22.0 20:00/20.0 NaN:NaN/NaN NaN:NaN/NaN”,“schedule_thursday”:“06:00/12.0 08:00/16.0 18:00/22.0 20:00/20.0 NaN:NaN/NaN NaN:NaN/NaN”,“schedule_tuesday”:“06:00/12.0 08:00/16.0 18:00/22.0 20:00/20.0 NaN:NaN/NaN NaN:NaN/NaN”,“schedule_wednesday”:“06:00/12.0 08:00/16.0 18:00/22.0 20:00/20.0 NaN:NaN/NaN NaN:NaN/NaN”,“system_mode”:“heat”}’
[3/14/2026, 9:17:13 PM] z2m:mqtt: MQTT publish: topic ‘zigbee2mqtt/Tuin_A_Spot_4’, payload ‘{“brightness”:254,“color”:{“x”:0.453,“y”:0.374},“color_mode”:“xy”,“color_temp”:404,“effect”:null,“linkquality”:160,“power_on_behavior”:“previous”,“state”:“OFF”,“update”:{“installed_version”:16787202,“latest_release_notes”:null,“latest_source”:“https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/Hue/100B-0114-01002702-ConfLightBLE-Lamps-EFR32MG21.zigbee",“latest_version”:16787202,“state”:"idle”}}’
[3/14/2026, 9:17:14 PM] zh:controller: Succesfully interviewed ‘0xffffb40e0605a3bd’
[3/14/2026, 9:17:14 PM] z2m: Successfully interviewed ‘0xffffb40e0605a3bd’, device has successfully been paired
[3/14/2026, 9:17:14 PM] z2m: Device ‘0xffffb40e0605a3bd’ is supported, identified as: Third Reality Smart Soil Moisture Sensor (3RSM0147Z)
[3/14/2026, 9:17:14 PM] z2m:mqtt: MQTT publish: topic ‘zigbee2mqtt/bridge/event’, payload ‘{“data”:{“definition”:{“description”:“Smart Soil Moisture Sensor”,“exposes”:[{“access”:5,“description”:“Measured temperature value”,“label”:“Temperature”,“name”:“temperature”,“property”:“temperature”,“type”:“numeric”,“unit”:“°C”},{“access”:5,“description”:“Measured soil moisture value”,“label”:“Soil moisture”,“name”:“soil_moisture”,“property”:“soil_moisture”,“type”:“numeric”,“unit”:“%”},{“access”:5,“category”:“diagnostic”,“description”:“Remaining battery in %”,“label”:“Battery”,“name”:“battery”,“property”:“battery”,“type”:“numeric”,“unit”:“%”,“value_max”:100,“value_min”:0},{“access”:1,“category”:“diagnostic”,“description”:“Link quality (signal strength)”,“label”:“Linkquality”,“name”:“linkquality”,“property”:“linkquality”,“type”:“numeric”,“unit”:“lqi”,“value_max”:255,“value_min”:0}],“model”:“3RSM0147Z”,“options”:[{“access”:2,“description”:“Calibrates the temperature value (absolute offset), takes into effect on next report of device.”,“label”:“Temperature calibration”,“name”:“temperature_calibration”,“property”:“temperature_calibration”,“type”:“numeric”,“value_step”:0.1},{“access”:2,“description”:“Number of digits after decimal point for temperature, takes into effect on next report of device. This option can only decrease the precision, not increase it.”,“label”:“Temperature precision”,“name”:“temperature_precision”,“property”:“temperature_precision”,“type”:“numeric”,“value_max”:3,“value_min”:0},{“access”:2,“description”:“Calibrates the soil_moisture value (absolute offset), takes into effect on next report of device.”,“label”:“Soil moisture calibration”,“name”:“soil_moisture_calibration”,“property”:“soil_moisture_calibration”,“type”:“numeric”,“value_step”:0.1},{“access”:2,“description”:“Number of digits after decimal point for soil_moisture, takes into effect on next report of device. This option can only decrease the precision, not increase it.”,“label”:“Soil moisture precision”,“name”:“soil_moisture_precision”,“property”:“soil_moisture_precision”,“type”:“numeric”,“value_max”:3,“value_min”:0}],“source”:“native”,“supports_ota”:true,“vendor”:“Third Reality”},“friendly_name”:“0xffffb40e0605a3bd”,“ieee_address”:“0xffffb40e0605a3bd”,“status”:“successful”,“supported”:true},“type”:“device_interview”}’
[3/14/2026, 9:17:15 PM] z2m:mqtt: MQTT publish: topic ‘zigbee2mqtt/0xffffb40e0605a3bd’, payload ‘{“battery”:100,“linkquality”:196,“soil_moisture”:null,“temperature”:26.08,“update”:{“installed_version”:-1,“latest_version”:-1,“state”:null}}’
[3/14/2026, 9:17:38 PM] frontend:api:bridge: Sending {“topic”:“bridge/request/device/rename”,“payload”:{“from”:“0xffffb40e0605a3bd”,“to”:“bodem_vochtigheid_02”,“homeassistant_rename”:true,“last”:null,“transaction”:“lnjrp-6”}}
[3/14/2026, 9:17:38 PM] z2m:mqtt: MQTT publish: topic ‘zigbee2mqtt/0xffffb40e0605a3bd’, payload ‘’
[3/14/2026, 9:17:38 PM] z2m:mqtt: MQTT publish: topic ‘zigbee2mqtt/0xffffb40e0605a3bd/availability’, payload ‘’
[3/14/2026, 9:17:38 PM] z2m:mqtt: MQTT publish: topic ‘homeassistant/sensor/0xffffb40e0605a3bd/temperature/config’, payload ‘’
[3/14/2026, 9:17:38 PM] z2m:mqtt: MQTT publish: topic ‘zigbee2mqtt/bodem_vochtigheid_02’, payload ‘{“battery”:100,“linkquality”:196,“soil_moisture”:null,“temperature”:26.08,“update”:{“installed_version”:-1,“latest_version”:-1,“state”:null}}’
[3/14/2026, 9:17:38 PM] z2m:mqtt: MQTT publish: topic ‘zigbee2mqtt/bridge/response/device/rename’, payload ‘{“data”:{“from”:“0xffffb40e0605a3bd”,“homeassistant_rename”:true,“to”:“bodem_vochtigheid_02”},“status”:“ok”,“transaction”:“lnjrp-6”}’
[3/14/2026, 9:17:38 PM] z2m:mqtt: MQTT publish: topic ‘zigbee2mqtt/bodem_vochtigheid_02/availability’, payload ‘{“state”:“online”}’
[3/14/2026, 9:17:38 PM] z2m:mqtt: MQTT publish: topic ‘homeassistant/sensor/0xffffb40e0605a3bd/soil_moisture/config’, payload ‘’
[3/14/2026, 9:17:38 PM] z2m:mqtt: MQTT publish: topic ‘homeassistant/sensor/0xffffb40e0605a3bd/battery/config’, payload ‘’
[3/14/2026, 9:17:38 PM] z2m:mqtt: MQTT publish: topic ‘homeassistant/sensor/0xffffb40e0605a3bd/linkquality/config’, payload ‘’
[3/14/2026, 9:17:38 PM] z2m:mqtt: MQTT publish: topic ‘homeassistant/update/0xffffb40e0605a3bd/update/config’, payload ‘’
[3/14/2026, 9:17:39 PM] z2m: Device ‘bodem_vochtigheid_02’ left the network
[3/14/2026, 9:17:39 PM] z2m:mqtt: MQTT publish: topic ‘zigbee2mqtt/bridge/event’, payload ‘{“data”:{“friendly_name”:“bodem_vochtigheid_02”,“ieee_address”:“0xffffb40e0605a3bd”},“type”:“device_leave”}’
[3/14/2026, 9:17:42 PM] zh:ember: [STACK STATUS] Network closed.
[3/14/2026, 9:17:43 PM] z2m:mqtt: MQTT publish: topic ‘zigbee2mqtt/Thermostaat_Radiator_Waskamer’, payload ‘{“battery_low”:false,“child_lock”:“UNLOCK”,“current_heating_setpoint”:21,“error”:null,“frost_protection”:null,“linkquality”:128,“local_temperature”:14,“local_temperature_calibration”:null,“pi_heating_demand”:null,“running_state”:“heat”,“scale_protection”:null,“schedule_friday”:“06:00/12.0 08:00/16.0 18:00/22.0 20:00/20.0 NaN:NaN/NaN NaN:NaN/NaN”,“schedule_monday”:“06:00/12.0 08:00/16.0 18:00/22.0 20:00/20.0 NaN:NaN/NaN NaN:NaN/NaN”,“schedule_saturday”:“06:00/12.0 08:00/16.0 18:00/22.0 20:00/20.0 NaN:NaN/NaN NaN:NaN/NaN”,“schedule_sunday”:“06:00/12.0 08:00/16.0 18:00/22.0 20:00/20.0 NaN:NaN/NaN NaN:NaN/NaN”,“schedule_thursday”:“06:00/12.0 08:00/16.0 18:00/22.0 20:00/20.0 NaN:NaN/NaN NaN:NaN/NaN”,“schedule_tuesday”:“06:00/12.0 08:00/16.0 18:00/22.0 20:00/20.0 NaN:NaN/NaN NaN:NaN/NaN”,“schedule_wednesday”:“06:00/12.0 08:00/16.0 18:00/22.0 20:00/20.0 NaN:NaN/NaN NaN:NaN/NaN”,“system_mode”:“heat”}’
maybe its cassual, but im in the same position.
I bought yesterday 2 sonoff device and i cant pair. not apears in zigbee2mqtt (with a conbee3 device).
i think its the sonoff, and i bought a aqara t2. and i have 2 of this aqara t2 working in my zigbee2mqtt, so the problem is not the device.
and the aqara t2, cant pair!! I dont know why :frowning:
Having this same issue. I have had three of these Third Reality moisture sensors deployed just fine for at least a year now. I went to deploy a few more than I have had laying around today and I can't get any of them to stay paired. They interview successfully and then leave the network. It's definitely not a connectivity issue and I have also paired other new devices today.
