I have a Problem with my HA installation. My Z2M doesn’t start when I have RaspberryMatic running. When I stop the RaspberryMatic Addon, then Z2M works fine, but as soon as I start RaspberryMatic, Z2M crashes.
I have the following setup:
HA VM running on ESXi
Skyconnect USB Stick for Z2M
Homematic RF Stick for RaspberryMatic
I have used the device id of the skyconnect in the Z2M config:
/dev/serial/by-id/usb-Nabu_Casa_SkyConnect_v1.0_5e9b12ab07deed1199d9ed2d62c613ac-if00-port0
However I cannot find the Homematic stick under the hardware tab in HA. Maybe RaspberryMatic blocks the USB ports?
Does anyone have a similar setup or knows what the issue might be? I have tried running RaspBerryMatic in a seperate VM but in this case I cannot connect any Homematic IP devices and I am unsure why.
The error message vom Z2M is that it could not start zigbee-herdsman (0.35.1)
Zigbee2MQTT:error 2024-03-28 12:13:40: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2024-03-28 12:13:40: Failed to start zigbee
Zigbee2MQTT:error 2024-03-28 12:13:40: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
Zigbee2MQTT:error 2024-03-28 12:13:40: Exiting...
Zigbee2MQTT:error 2024-03-28 12:13:40: Error: Failure send version:{"type":"Buffer","data":[0,0,0,4]}
at /app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/ezsp.ts:664:23
at Queue.execute (/app/node_modules/zigbee-herdsman/src/utils/queue.ts:35:20)
at Ezsp.version (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/ezsp.ts:469:24)
at Driver.startup (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/driver.ts:172:9)
at Controller.start (/app/node_modules/zigbee-herdsman/src/controller/controller.ts:132:29)
at Zigbee.start (/app/lib/zigbee.ts:62:27)
at Controller.start (/app/lib/controller.ts:109:27)
at start (/app/index.js:107:5)
Sometimes it starts but crashes right after:
Zigbee2MQTT:error 2024-03-28 11:42:59: Adapter disconnected, stopping
Zigbee2MQTT:info 2024-03-28 11:42:59: MQTT publish: topic 'zigbee2mqtt/bridge/state', payload '{"state":"offline"}'
Zigbee2MQTT:info 2024-03-28 11:42:59: Disconnecting from MQTT server
Zigbee2MQTT:info 2024-03-28 11:42:59: Stopping zigbee-herdsman...
Zigbee2MQTT:error 2024-03-28 11:42:59: Failed to stop Zigbee2MQTT
