z2m don’t started, but started in logs
I tried to uninstall and reinstall z2m, even delete the z2m folder in config, it doesn’t change anything, even the old logs are still visible in the module log
[16:49:05] INFO: Preparing to start...
[16:49:05] INFO: Socat enabled
[16:49:05] INFO: Starting socat
Socat startup parameters:
Options: -d -d
Master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
Slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
[16:49:06] INFO: Starting socat process ...
2024/05/12 16:49:06 socat[47] N PTY is /dev/pts/1
2024/05/12 16:49:06 socat[47] N listening on AF=2 0.0.0.0:8485
[16:49:07] INFO: Starting Zigbee2MQTT...
[2024-05-12 16:49:12] info: z2m: Logging to console, file (filename: log.log)
[2024-05-12 16:49:12] info: z2m: Starting Zigbee2MQTT version 1.37.1 (commit #unknown)
[2024-05-12 16:49:12] info: z2m: Starting zigbee-herdsman (0.46.6)
[2024-05-12 16:49:13] warning: zh:ezsp: Deprecated driver 'ezsp' currently in use, 'ember' will become the officially supported EmberZNet driver in next release. If using Zigbee2MQTT see https://github.com/Koenkk/zigbee2mqtt/discussions/21462
[2024-05-12 16:49:16] info: zh:ezsp:driv: Leaving current network and forming new network
[2024-05-12 16:49:17] info: zh:ezsp:driv: Form network
[2024-05-12 16:49:18] info: zh:controller: Wrote coordinator backup to '/config/zigbee2mqtt/coordinator_backup.json'
[2024-05-12 16:49:18] info: z2m: zigbee-herdsman started (reset)
[2024-05-12 16:49:18] info: z2m: Coordinator firmware version: '{"meta":{"maintrel":"1 ","majorrel":"7","minorrel":"4","product":13,"revision":"7.4.1.0 build 0"},"type":"EZSP v13"}'
[2024-05-12 16:49:19] info: z2m: Currently 0 devices are joined:
[2024-05-12 16:49:19] info: z2m: Zigbee: disabling joining new devices.
[2024-05-12 16:49:19] info: z2m: Connecting to MQTT server at mqtt://192.168.1.137:1883
[2024-05-12 16:49:19] info: z2m: Connected to MQTT server
[2024-05-12 16:49:19] info: z2m: Started frontend on port 8099
[2024-05-12 16:49:19] info: z2m: Zigbee2MQTT started!
