Z2m error without any reason to
Suddenly my zigbee devices stopped working yesterday, I have z2m, and looking in the log it states this:
[2024-10-11 08:47:07] error: 	z2m: Error while starting zigbee-herdsman
[2024-10-11 08:47:07] error: 	z2m: Failed to start zigbee
[2024-10-11 08:47:07] error: 	z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
[2024-10-11 08:47:07] error: 	z2m: Exiting...
[2024-10-11 08:47:07] error: 	z2m: Error: Failed to start EZSP layer with status=HOST_FATAL_ERROR.
    at EmberAdapter.initEzsp (/app/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:684:19)
    at EmberAdapter.start (/app/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:1583:24)
    at Controller.start (/app/node_modules/zigbee-herdsman/src/controller/controller.ts:137:29)
    at Zigbee.start (/app/lib/zigbee.ts:69:27)
    at Controller.start (/app/lib/controller.ts:161:27)
    at start (/app/index.js:154:5)
Checked out the website, but this error is not noted there.
Iā€™m really dependent on my zigbee devices as a disabled person.
is there anyone who can help me?
I tried a full restart of the whole HAS machine also.
Cheers, Frank
Try reseating the adapter. You can also try a firmware update.
If I could give you a big bear hug I would.
You saved my day, thank you fleskefjes, you rock.
I did a firmware upgrade.
Cheers, Frank
