Z2M Errors on Start - JS out of memory
Note down what devices are missing at the moment and when you re-pair make sure you name them like the old names. Less hassle with dashboards and automations that way.
Slowly coming back, few of the usual issues lol. Thanks for your help everyone :clap: :clap: :clap:
Hi, writing this comment, to help other lost souls, because I had problems with the migration from zstack to ember with the error z2m: Error: [BACKUP] Current backup file is not for EmberZNet stack. even after changing the IEEE according to FAQ | Zigbee2MQTT (was a bit pain under W11 with WSL [see usbipd]), too.
  1. stop z2m
  2. backup from zigbee2mqtt (or data) directory (this is to make a clean rollback if needed)
  • configuration.yaml
  • coordinator_backup.json
  • database.db (warning: under VSCode it’s usually hidden!)
  • state.json
  1. rename coordinator_backup.json to e.g. coordinator_backup.save.json
  2. In the zigbee2mqtt/configuration.yaml
  • change serial adapter to adapter: ember (maybe port, for me it stayed port: /dev/ttyUSB0
  • maybe in advanced to transmit_power: 20
  1. start z2m to generate a new coordinator_backup.json
  • now the error occurs
  1. stop z2m
  2. in coordinator_backup.json
  • copy everything from coordinator_backup.save.json expect the first 2 blocks (metadata and stack_specific) and save
    For me I first tried to keep the new coordinator_ieee (although I changed and checked it according to the link above) and the extended_pan_id, which was a mess.
  1. start z2m again
For me this worked flawless after my initial fail
