Hi Folks,
On start Z2M fails to start properly, some Z2M devices work fine but things like temperature sensors and lightbulbs don’t. Z2M log shows the below after restart. The controller is a CC2531 s below:
Any help appreciated. I just wonder if the controller is failing?
ttyACM0
/dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B001CCC433C-if00
[11:35:30] INFO: Preparing to start…
[11:35:30] INFO: Socat not enabled
[11:35:31] INFO: Starting Zigbee2MQTT…
Starting Zigbee2MQTT without watchdog.
[2024-11-10 11:49:53] error: zh:controller:device: Handling of poll check-in from 0x38398ffffeec651a failed (ZCL command 0x38398ffffeec651a/1 genPollCtrl.checkinRsp({“startFastPolling”:false,“fastPollTimeout”:0}, {“timeout”:10000,“disableResponse”:false,“disableRecovery”:false,“disableDefaultResponse”:false,“direction”:0,“reservedBits”:0,“writeUndiv”:false,“sendPolicy”:“immediate”}) failed (Timeout - 11061 - 1 - 57 - 32 - 11 after 10000ms))
<— Last few GCs —>
[7:0x7fb8b39590] 13845082 ms: Mark-Compact 2043.0 (2089.4) → 2039.2 (2089.6) MB, 5006.62 / 0.00 ms (average mu = 0.130, current mu = 0.034) allocation failure; scavenge might not succeed
[7:0x7fb8b39590] 13849881 ms: Mark-Compact 2043.2 (2089.6) → 2039.4 (2089.9) MB, 4295.86 / 0.00 ms (average mu = 0.118, current mu = 0.105) allocation failure; scavenge might not succeed
<— JS stacktrace —>
FATAL ERROR: Ineffective mark-compacts near heap limit Allocation failed - JavaScript heap out of memory
----- Native stack trace -----
