Z2m failed to connect to zigate adapter
Hi
I have HA Supervised installed on raspberry pi 3 b+ pizigate v1 firmware 3.xx
I tried to install Z2M but i have a problem :
Starting Zigbee2MQTT version 1.40.2 (commit #unknown)
[2024-10-12 19:29:34] info: 	z2m: Starting zigbee-herdsman (2.1.3)
[2024-10-12 19:29:35] error: 	z2m: Error while starting zigbee-herdsman
[2024-10-12 19:29:35] error: 	z2m: Failed to start zigbee
[2024-10-12 19:29:35] error: 	z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
[2024-10-12 19:29:35] error: 	z2m: Exiting...
[2024-10-12 19:29:35] error: 	z2m: Error: failed to connect to zigate adapter Error: I/O error setting custom baud rate of 115200
    at ZiGateAdapter.start (/app/node_modules/zigbee-herdsman/src/adapter/zigate/adapter/zigateAdapter.ts:95:19)
    at Controller.start (/app/node_modules/zigbee-herdsman/src/controller/controller.ts:137:29)
    at Zigbee.start (/app/lib/zigbee.ts:69:27)
    at Controller.start (/app/lib/controller.ts:161:27)
    at start (/app/index.js:154:5)
Hi ,
My suggestion , if you haven’t already, is to use the long name for the stick. Not the usb port string.
Then as things reboot and the actual port changes in the back-end, the correct device will be addressed.
Mine looks like this:
/dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0883963e9ec8abc123456c5c3de5b81b4-if00-port0
Have you looked into the baud rate and checked that 115200 is the correct one?
