Hi guys, I’m new to Proxmox, HA, and all of these good stuff. I followed this guide to set up my Z2M container: https://smarthomescene.com/guides/how-to-separate-zigbee2mqtt-from-home-assistant-in-proxmox/. Recently I ran into the above mentioned problem. Here is the log and the configuration file what I have:
root@zigbee2mqtt:~# cd /opt/zigbee2mqtt && npm start
> [email protected] start
> node index.js
Zigbee2MQTT:info 2023-12-01 18:23:17: Logging to console and directory: '/opt/zigbee2mqtt/data/log/2023-12-01.18-23-17' filename: log.txt
Zigbee2MQTT:info 2023-12-01 18:23:17: Starting Zigbee2MQTT version 1.33.2-dev (commit #4e128e26)
Zigbee2MQTT:info 2023-12-01 18:23:17: Starting zigbee-herdsman (0.23.0)
Zigbee2MQTT:error 2023-12-01 18:23:37: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2023-12-01 18:23:37: Failed to start zigbee
Zigbee2MQTT:error 2023-12-01 18:23:37: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
Zigbee2MQTT:error 2023-12-01 18:23:37: Exiting...
Zigbee2MQTT:error 2023-12-01 18:23:37: Error: Connection not initialized
at Ezsp.execCommand (/opt/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/ezsp.ts:551:19)
at Ezsp.version (/opt/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/ezsp.ts:349:35)
at Driver.startup (/opt/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/driver.ts:140:25)
at EZSPAdapter.start (/opt/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/ezsp/adapter/ezspAdapter.ts:172:16)
at Controller.start (/opt/zigbee2mqtt/node_modules/zigbee-herdsman/src/controller/controller.ts:132:29)
at Zigbee.start (/opt/zigbee2mqtt/lib/zigbee.ts:60:27)
at Controller.start (/opt/zigbee2mqtt/lib/controller.ts:101:27)
at start (/opt/zigbee2mqtt/index.js:107:5)
root@zigbee2mqtt:/opt/zigbee2mqtt#
frontend:
port: 8080
homeassistant: true
permit_join: false
mqtt:
base_topic: zigbee2mqtt
server: mqtt://192.168.0.215:18083
user: user
password: password
keepalive: 60
reject_unauthorized: true
version: 4
serial:
port: /dev/serial/by-id/usb-Nabu_Casa_SkyConnect_v1.0_10705708687ded118905ec764fc49859-if00-port0
adapter: ezsp
advanced:
pan_id: 60310
network_key:
- 70
- 35
- 232
- 159
- 138
- 171
- 242
- 224
- 193
- 36
- 65
- 159
- 9
- 203
- 52
- 236
channel: 20
What am I doing wrong?
