Here is a log file snippet:
Successfully configured 'Private office light 6'
Successfully configured 'Private office light 5'
Successfully configured 'Private office light 4'
Successfully configured 'Private office light 3'
Successfully configured 'Private office light 2'
Successfully configured 'Private office light 1'
Configuring 'Private office light 6'
Configuring 'Private office light 5'
Configuring 'Private office light 4'
Configuring 'Private office light 3'
Configuring 'Private office light 2'
Configuring 'Private office light 1'
Successfully unbound cluster 'genOnOff' from 'Private office light remote' to 'private_office_light'
Failed to apply calibration to 'temperature': 'temperature_calibration' is not a number, got string ()
Successfully unbound cluster 'genLevelCtrl' from 'Private office light remote' to 'private_office_light'
[[email protected]](https://home.wickhay.uk/api/hassio_ingress/4WOEqLPKQBSAE_UoFRZvmyFvbg2mszZTogQRlXwq0rQ/#/)
* [Devices](https://home.wickhay.uk/api/hassio_ingress/4WOEqLPKQBSAE_UoFRZvmyFvbg2mszZTogQRlXwq0rQ/#/)
* [Dashboard](https://home.wickhay.uk/api/hassio_ingress/4WOEqLPKQBSAE_UoFRZvmyFvbg2mszZTogQRlXwq0rQ/#/dashboard)
* [Map](https://home.wickhay.uk/api/hassio_ingress/4WOEqLPKQBSAE_UoFRZvmyFvbg2mszZTogQRlXwq0rQ/#/map)
* [Settings](https://home.wickhay.uk/api/hassio_ingress/4WOEqLPKQBSAE_UoFRZvmyFvbg2mszZTogQRlXwq0rQ/#/settings)
* [Groups](https://home.wickhay.uk/api/hassio_ingress/4WOEqLPKQBSAE_UoFRZvmyFvbg2mszZTogQRlXwq0rQ/#/groups)
* [OTA](https://home.wickhay.uk/api/hassio_ingress/4WOEqLPKQBSAE_UoFRZvmyFvbg2mszZTogQRlXwq0rQ/#/ota)
* [Touchlink](https://home.wickhay.uk/api/hassio_ingress/4WOEqLPKQBSAE_UoFRZvmyFvbg2mszZTogQRlXwq0rQ/#/touchlink)
* [Logs](https://home.wickhay.uk/api/hassio_ingress/4WOEqLPKQBSAE_UoFRZvmyFvbg2mszZTogQRlXwq0rQ/#/logs)
* [Extensions](https://home.wickhay.uk/api/hassio_ingress/4WOEqLPKQBSAE_UoFRZvmyFvbg2mszZTogQRlXwq0rQ/#/extensions)
* [![English](https://home.wickhay.uk/api/hassio_ingress/4WOEqLPKQBSAE_UoFRZvmyFvbg2mszZTogQRlXwq0rQ/assets/uk-9b7898ef.png)](https://home.wickhay.uk/api/hassio_ingress/4WOEqLPKQBSAE_UoFRZvmyFvbg2mszZTogQRlXwq0rQ/#)
Show only
Filter by text
info <small>2024-04-07 10:31:04</small>`MQTT
publish: topic 'zigbee2mqtt/Loft gas sensor', payload
'{"carbon_monoxide":false,"co":0,"gas":false,"gas_value":0.003,"last_seen":"2024-04-07T09:30:41.125Z","linkquality":208}'`
debug <small>2024-04-07 10:31:04</small>`Received
Zigbee message from 'Loft gas sensor', type 'commandDataReport',
cluster 'manuSpecificTuya', data
'{"dpValues":[{"data":{"data":[1],"type":"Buffer"},"datatype":4,"dp":18}],"seq":8704}'
from endpoint 1 with groupID 0`
'{"carbon_monoxide":false,"co":0,"gas":false,"gas_value":0.003,"last_seen":"2024-04-07T09:30:41.208Z","linkquality":208}'`
'{"dpValues":[{"data":{"data":[0,0,0,2],"type":"Buffer"},"datatype":2,"dp":19}],"seq":8960}'
'{"carbon_monoxide":false,"co":0,"gas":false,"gas_value":0.003,"last_seen":"2024-04-07T09:30:41.287Z","linkquality":208}'`
Zigbee message from '0x0015bc00340010e5', type 'read', cluster
'genTime', data '["time"]' from endpoint 35 with groupID 0`
publish: topic 'zigbee2mqtt/0x0015bc00340010e5', payload
'{"alarm":null,"battery":80,"battery_low":false,"enrolled":false,"fault":false,"ias_cie_address":"0xffffffffffffffff","last_seen":"2024-04-07T09:30:41.491Z","linkquality":160,"max_duration":240,"reliability":"no_fault_detected","smoke":null,"temperature":22.81,"test":null,"update":{"installed_version":262152,"latest_version":262152,"state":"idle"},"update_available":null,"voltage":2900,"zone_id":255}'`
Zigbee message from 'Private office light remote', type
'commandHueNotification', cluster 'manuSpecificPhilips', data
'{"button":2,"time":0,"type":0,"unknown1":3145728,"unknown2":0}' from
publish: topic 'zigbee2mqtt/Private office light remote', payload
'{"action":"up_press","battery":100,"last_seen":"2024-04-07T09:30:41.509Z","linkquality":255,"update":{"installed_version":33565954,"latest_version":33565954,"state":"idle"},"update_available":null}'`
'{"action":"","battery":100,"last_seen":"2024-04-07T09:30:41.509Z","linkquality":255,"update":{"installed_version":33565954,"latest_version":33565954,"state":"idle"},"update_available":null}'`
info <small>2024-04-07 10:31:04</small>`MQTT publish: topic 'zigbee2mqtt/Private office light remote/action', payload 'up_press'`
Zigbee message from 'Private office light remote', type 'commandStep',
cluster 'genLevelCtrl', data
'{"stepmode":0,"stepsize":30,"transtime":9}' from endpoint 1 with
groupID 0`
'{"action":null,"battery":100,"last_seen":"2024-04-07T09:30:41.520Z","linkquality":255,"update":{"installed_version":33565954,"latest_version":33565954,"state":"idle"},"update_available":null}'`
MQTT message on 'zigbee2mqtt/bridge/request/device/unbind' with data
'{"clusters":["genLevelCtrl","genOnOff"],"from":"Private office light
remote/1","to":"private_office_light","transaction":"fsdx2-1"}'`
debug <small>2024-04-07 10:31:04</small>`unbinding cluster 'genLevelCtrl' from 'Private office light remote' to 'private_office_light'`
debug <small>2024-04-07 10:31:05</small>`Received
'{"stepmode":0,"stepsize":63,"transtime":9}' from endpoint 1 with
groupID 0`
info <small>2024-04-07 10:31:05</small>`MQTT
'{"action":null,"battery":100,"last_seen":"2024-04-07T09:30:42.227Z","linkquality":255,"update":{"installed_version":33565954,"latest_version":33565954,"state":"idle"},"update_available":null}'`
'{"button":2,"time":8,"type":1,"unknown1":3145728,"unknown2":0}' from
'{"action":"up_hold","action_duration":0.745,"battery":100,"last_seen":"2024-04-07T09:30:42.255Z","linkquality":255,"update":{"installed_version":33565954,"latest_version":33565954,"state":"idle"},"update_available":null}'`
'{"action":"","battery":100,"last_seen":"2024-04-07T09:30:42.255Z","linkquality":255,"update":{"installed_version":33565954,"latest_version":33565954,"state":"idle"},"update_available":null}'`
info <small>2024-04-07 10:31:05</small>`MQTT publish: topic 'zigbee2mqtt/Private office light remote/action', payload 'up_hold'`
'{"dpValues":[{"data":{"data":[1],"type":"Buffer"},"datatype":4,"dp":1}],"seq":9472}'
'{"carbon_monoxide":false,"co":0,"gas":false,"gas_value":0.003,"last_seen":"2024-04-07T09:30:42.548Z","linkquality":204}'`
debug <small>2024-04-07 10:31:06</small>`Received
info <small>2024-04-07 10:31:06</small>`MQTT
'{"carbon_monoxide":false,"co":0,"gas":false,"gas_value":0.003,"last_seen":"2024-04-07T09:30:42.749Z","linkquality":208}'`
'{"carbon_monoxide":false,"co":0,"gas":false,"gas_value":0.003,"last_seen":"2024-04-07T09:30:42.953Z","linkquality":208}'`
groupID 0`
'{"action":null,"battery":100,"last_seen":"2024-04-07T09:30:43.028Z","linkquality":255,"update":{"installed_version":33565954,"latest_version":33565954,"state":"idle"},"update_available":null}'`
'{"button":2,"time":16,"type":1,"unknown1":3145728,"unknown2":0}' from
'{"action":"up_hold","action_duration":1.548,"battery":100,"last_seen":"2024-04-07T09:30:43.058Z","linkquality":255,"update":{"installed_version":33565954,"latest_version":33565954,"state":"idle"},"update_available":null}'`
'{"action":"","battery":100,"last_seen":"2024-04-07T09:30:43.058Z","linkquality":255,"update":{"installed_version":33565954,"latest_version":33565954,"state":"idle"},"update_available":null}'`
info <small>2024-04-07 10:31:06</small>`MQTT publish: topic 'zigbee2mqtt/Private office light remote/action', payload 'up_hold'`
'{"carbon_monoxide":false,"co":0,"gas":false,"gas_value":0.003,"last_seen":"2024-04-07T09:30:43.148Z","linkquality":208}'`
'{"carbon_monoxide":false,"co":0,"gas":false,"gas_value":0.003,"last_seen":"2024-04-07T09:30:43.348Z","linkquality":208}'`
'{"carbon_monoxide":false,"co":0,"gas":false,"gas_value":0.003,"last_seen":"2024-04-07T09:30:43.549Z","linkquality":208}'`
debug <small>2024-04-07 10:31:07</small>`Received
info <small>2024-04-07 10:31:07</small>`MQTT
'{"carbon_monoxide":false,"co":0,"gas":false,"gas_value":0.003,"last_seen":"2024-04-07T09:30:43.751Z","linkquality":208}'`
groupID 0`
'{"action":null,"battery":100,"last_seen":"2024-04-07T09:30:43.840Z","linkquality":255,"update":{"installed_version":33565954,"latest_version":33565954,"state":"idle"},"update_available":null}'`
'{"button":2,"time":24,"type":1,"unknown1":3145728,"unknown2":0}' from
'{"action":"up_hold","action_duration":2.346,"battery":100,"last_seen":"2024-04-07T09:30:43.855Z","linkquality":255,"update":{"installed_version":33565954,"latest_version":33565954,"state":"idle"},"update_available":null}'`
'{"action":"","battery":100,"last_seen":"2024-04-07T09:30:43.855Z","linkquality":255,"update":{"installed_version":33565954,"latest_version":33565954,"state":"idle"},"update_available":null}'`
info <small>2024-04-07 10:31:07</small>`MQTT publish: topic 'zigbee2mqtt/Private office light remote/action', payload 'up_hold'`
'{"carbon_monoxide":false,"co":0,"gas":false,"gas_value":0.003,"last_seen":"2024-04-07T09:30:43.951Z","linkquality":212}'`
'{"carbon_monoxide":false,"co":0,"gas":false,"gas_value":0.003,"last_seen":"2024-04-07T09:30:44.150Z","linkquality":208}'`
Zigbee message from 'Freezer bottom monitor ', type 'attributeReport',
cluster 'msTemperatureMeasurement', data '{"measuredValue":-1798}' from
error <small>2024-04-07 10:31:07</small>`Failed to apply calibration to 'temperature': 'temperature_calibration' is not a number, got string ()`
publish: topic 'zigbee2mqtt/Freezer bottom monitor ', payload
'{"battery":21,"humidity":80.92,"last_seen":"2024-04-07T09:30:44.331Z","linkquality":255,"temperature":-17.98,"voltage":2600}'`
'{"carbon_monoxide":false,"co":0,"gas":false,"gas_value":0.003,"last_seen":"2024-04-07T09:30:44.351Z","linkquality":208}'`
'{"carbon_monoxide":false,"co":0,"gas":false,"gas_value":0.003,"last_seen":"2024-04-07T09:30:44.552Z","linkquality":208}'`
groupID 0`
'{"action":null,"battery":100,"last_seen":"2024-04-07T09:30:44.635Z","linkquality":255,"update":{"installed_version":33565954,"latest_version":33565954,"state":"idle"},"update_available":null}'`
'{"button":2,"time":32,"type":1,"unknown1":3145728,"unknown2":0}' from
'{"action":"up_hold","action_duration":3.151,"battery":100,"last_seen":"2024-04-07T09:30:44.661Z","linkquality":255,"update":{"installed_version":33565954,"latest_version":33565954,"state":"idle"},"update_available":null}'`
'{"action":"","battery":100,"last_seen":"2024-04-07T09:30:44.661Z","linkquality":255,"update":{"installed_version":33565954,"latest_version":33565954,"state":"idle"},"update_available":null}'`
debug <small>2024-04-07 10:31:08</small>`Received
info <small>2024-04-07 10:31:08</small>`MQTT
'{"carbon_monoxide":false,"co":0,"gas":false,"gas_value":0.003,"last_seen":"2024-04-07T09:30:44.753Z","linkquality":208}'`
'{"carbon_monoxide":false,"co":0,"gas":false,"gas_value":0.003,"last_seen":"2024-04-07T09:30:44.951Z","linkquality":208}'`
info <small>2024-04-07 10:31:08</small>`Successfully unbound cluster 'genLevelCtrl' from 'Private office light remote' to 'private_office_light'`
debug <small>2024-04-07 10:31:08</small>`unbinding cluster 'genOnOff' from 'Private office light remote' to 'private_office_light'`
'{"dpValues":[{"data":{"data":[0,0,0,3],"type":"Buffer"},"datatype":2,"dp":2}],"seq":9728}'
'{"carbon_monoxide":false,"co":0,"gas":false,"gas_value":0.003,"last_seen":"2024-04-07T09:30:45.100Z","linkquality":208}'`
error <small>2024-04-07 10:31:08</small>`Failed to apply calibration to 'temperature': 'temperature_calibration' is not a number, got string ()`
'{"battery":21,"humidity":80.92,"last_seen":"2024-04-07T09:30:45.295Z","linkquality":255,"temperature":-17.98,"voltage":2600}'`
'{"carbon_monoxide":false,"co":0,"gas":false,"gas_value":0.003,"last_seen":"2024-04-07T09:30:45.368Z","linkquality":208}'`
info <small>2024-04-07 10:31:08</small>`Successfully unbound cluster 'genOnOff' from 'Private office light remote' to 'private_office_light'`
info <small>2024-04-07 10:31:16</small>`Configuring 'Private office light 1'`
info <small>2024-04-07 10:31:17</small>`Configuring 'Private office light 2'`
info <small>2024-04-07 10:31:17</small>`Configuring 'Private office light 3'`
info <small>2024-04-07 10:31:17</small>`Configuring 'Private office light 4'`
info <small>2024-04-07 10:31:17</small>`Configuring 'Private office light 5'`
info <small>2024-04-07 10:31:17</small>`Configuring 'Private office light 6'`
info <small>2024-04-07 10:31:17</small>`MQTT
publish: topic 'zigbee2mqtt/bridge/response/device/unbind', payload
'{"data":{"clusters":["genLevelCtrl","genOnOff"],"failed":[],"from":"Private
office light
remote/1","to":"private_office_light"},"status":"ok","transaction":"fsdx2-1"}'`
debug <small>2024-04-07 10:31:17</small>`Received
groupID 0`
'{"button":2,"time":40,"type":1,"unknown1":3145728,"unknown2":0}' from
'{"action":null,"battery":100,"last_seen":"2024-04-07T09:30:54.283Z","linkquality":255,"update":{"installed_version":33565954,"latest_version":33565954,"state":"idle"},"update_available":null}'`
'{"action":"up_hold","action_duration":12.782,"battery":100,"last_seen":"2024-04-07T09:30:54.283Z","linkquality":255,"update":{"installed_version":33565954,"latest_version":33565954,"state":"idle"},"update_available":null}'`
'{"carbon_monoxide":false,"co":0,"gas":false,"gas_value":0.003,"last_seen":"2024-04-07T09:30:54.285Z","linkquality":208}'`
'{"action":"","battery":100,"last_seen":"2024-04-07T09:30:54.283Z","linkquality":255,"update":{"installed_version":33565954,"latest_version":33565954,"state":"idle"},"update_available":null}'`
info <small>2024-04-07 10:31:17</small>`MQTT publish: topic 'zigbee2mqtt/Private office light remote/action', payload 'up_hold'`
info <small>2024-04-07 10:31:22</small>`Successfully configured 'Private office light 1'`
info <small>2024-04-07 10:31:29</small>`Successfully configured 'Private office light 2'`
info <small>2024-04-07 10:31:29</small>`Successfully configured 'Private office light 3'`
info <small>2024-04-07 10:31:29</small>`Successfully configured 'Private office light 4'`
info <small>2024-04-07 10:31:29</small>`Successfully configured 'Private office light 5'`
info <small>2024-04-07 10:31:29</small>`Successfully configured 'Private office light 6'`
debug <small>2024-04-07 10:31:33</small>`Received
info <small>2024-04-07 10:31:33</small>`MQTT
'{"carbon_monoxide":false,"co":0,"gas":false,"gas_value":0.003,"last_seen":"2024-04-07T09:31:10.299Z","linkquality":168}'`
