Here’s my work-in-progress blueprint for the Inovelli Blue Series switch, model VZM31-SN for use with Zigbee2MQTT. This exposes all the button combinations for you to do with what you please. For example, double press down to turn off every light in the house. Press and hold up to slowly turn the brightness of the entire room up until you release the button. Have fun. Check out my other blueprint for some tips if you need help: Zigbee2Mqtt - IKEA five button remote
blueprint:
name: Z2M - Inovelli 2-in-1 switch + dimmer Scene Controls
description: |
For Inovelli Blue Series 2-in-1 switch + dimmer, model VZM31-SN
Allows setting a few different actions such as 2,3,4,5 clicking the up/down and config buttons.
domain: automation
input:
switch:
description: Inovelli Switch (action). For example, "sensor.INOVELLI_SWITCH_action"
selector:
entity:
domain: sensor
config_held:
description: Action to run
default: []
selector:
config_release:
default: []
selector:
config_single:
name: Single Click Config
default: []
selector:
config_double:
name: Double Click Config
default: []
selector:
config_triple:
name: 3x Click Config
default: []
selector:
config_quadruple:
name: 4x Click Config
default: []
selector:
config_quintuple:
name: 5x Click Config
default: []
selector:
down_held:
default: []
selector:
down_release:
default: []
selector:
down_single:
name: Single Click Down
description: This will trigger an/some action(s), but also, it will probably turn off the switch locally.
default: []
selector:
down_double:
name: Double Click Down
default: []
selector:
down_triple:
name: 3x Click Down
default: []
selector:
down_quadruple:
name: 4x Click Down
default: []
selector:
down_quintuple:
name: 5x Click Down
default: []
selector:
up_held:
default: []
selector:
up_release:
default: []
selector:
up_single:
name: Single Click Up
description: This will trigger an/some action(s), but also, it will probably turn on the switch locally.
default: []
selector:
up_double:
name: Double Click Up
default: []
selector:
up_triple:
name: 3x Click Up
default: []
selector:
up_quadruple:
name: 4x Click Up
default: []
selector:
up_quintuple:
name: 5x Click Up
default: []
selector:
mode: parallel
max_exceeded: silent
- platform: state
entity_id: !input switch
- variables:
command: "{{ trigger.to_state.state }}"
- choose:
- conditions:
- "{{ command == 'config_double' }}"
sequence: !input config_double
- conditions:
- "{{ command == 'config_held' }}"
sequence: !input config_held
- conditions:
- "{{ command == 'config_quadruple' }}"
sequence: !input config_quadruple
- conditions:
- "{{ command == 'config_quintuple' }}"
sequence: !input config_quintuple
- conditions:
- "{{ command == 'config_release' }}"
sequence: !input config_release
- conditions:
- "{{ command == 'config_single' }}"
sequence: !input config_single
- conditions:
- "{{ command == 'config_triple' }}"
sequence: !input config_triple
- conditions:
- "{{ command == 'down_double' }}"
sequence: !input down_double
- conditions:
- "{{ command == 'down_held' }}"
sequence: !input down_held
- conditions:
- "{{ command == 'down_quadruple' }}"
sequence: !input down_quadruple
- conditions:
- "{{ command == 'down_quintuple' }}"
sequence: !input down_quintuple
- conditions:
- "{{ command == 'down_release' }}"
sequence: !input down_release
- conditions:
- "{{ command == 'down_single' }}"
sequence: !input down_single
- conditions:
- "{{ command == 'down_triple' }}"
sequence: !input down_triple
- conditions:
- "{{ command == 'up_double' }}"
sequence: !input up_double
- conditions:
- "{{ command == 'up_held' }}"
sequence: !input up_held
- conditions:
- "{{ command == 'up_quadruple' }}"
sequence: !input up_quadruple
- conditions:
- "{{ command == 'up_quintuple' }}"
sequence: !input up_quintuple
- conditions:
- "{{ command == 'up_release' }}"
sequence: !input up_release
- conditions:
- "{{ command == 'up_single' }}"
sequence: !input up_single
- conditions:
- "{{ command == 'up_triple' }}"
sequence: !input up_triple
edited the order of inputs
Added missing import button
