Z2m issues with a Thermostat Sonoff TRVZB after update
Hi there,
after updating to the latest Z2M version, I had to manually insert the adapter: zstack line that it works again
Now I have a thermostat throwing this line:
error <small>2025-02-04 13:43:38</small>z2m: Publish ‘set’ ‘local_temperature_calibration’ to ‘Vertrieb/Service Thermostat’ failed: ‘Error: ZCL command 0x8c65a3fffee099a0/1 hvacThermostat.write({“localTemperatureCalibration”:-28}, {“timeout”:10000,“disableResponse”:false,“disableRecovery”:false,“disableDefaultResponse”:true,“direction”:0,“reservedBits”:0,“writeUndiv”:false}) failed (Timeout - 63138 - 1 - 54 - 513 - 4 after 10000ms)’`
And this one:
error <small>2025-02-04 13:49:48</small>z2m: Publish ‘set’ ‘local_temperature_calibration’ to ‘Vertrieb/Service Thermostat’ failed: ‘Error: ZCL command 0x8c65a3fffee099a0/1 hvacThermostat.write({“localTemperatureCalibration”:-26}, {“timeout”:10000,“disableResponse”:false,“disableRecovery”:false,“disableDefaultResponse”:true,“direction”:0,“reservedBits”:0,“writeUndiv”:false}) failed (ZCL command 0x8c65a3fffee099a0/1 hvacThermostat.write({“localTemperatureCalibration”:-26}, {“timeout”:10000,“disableResponse”:false,“disableRecovery”:false,“disableDefaultResponse”:true,“direction”:0,“reservedBits”:0,“writeUndiv”:false}) failed (ZCL command 0x8c65a3fffee099a0/1 hvacThermostat.write({“localTemperatureCalibration”:-26}, {“timeout”:10000,“disableResponse”:false,“disableRecovery”:false,“disableDefaultResponse”:true,“direction”:0,“reservedBits”:0,“writeUndiv”:false}) failed (ZCL command 0x8c65a3fffee099a0/1 hvacThermostat.write({“localTemperatureCalibration”:-26}, {“timeout”:10000,“disableResponse”:false,“disableRecovery”:false,“disableDefaultResponse”:true,“direction”:0,“reservedBits”:0,“writeUndiv”:false}) failed (ZCL command 0x8c65a3fffee099a0/1 hvacThermostat.write({“localTemperatureCalibration”:-26}, {“timeout”:10000,“disableResponse”:false,“disableRecovery”:false,“disableDefaultResponse”:true,“direction”:0,“reservedBits”:0,“writeUndiv”:false}) failed (ZCL command 0x8c65a3fffee099a0/1 hvacThermostat.write({“localTemperatureCalibration”:-26}, {“timeout”:10000,“disableResponse”:false,“disableRecovery”:false,“disableDefaultResponse”:true,“direction”:0,“reservedBits”:0,“writeUndiv”:false}) failed (Timeout - 63138 - 1 - 122 - 513 - 4 after 10000ms))))))’`
The Thermostat can still be used locally and the actual set temperature is showing in Z2M
But I can’t set any setting on this thermostat.
I had the same issue with other thermostats (same model) but those could be fixed by simply powercycle them. Strangely all affected thermostat are located in the same office space (only one out of 5 continued working as intended)
Can anyone help me with that?
Have you tried deleting it and then re-pairing it to Z2M?
I will try that
