I looked into the logs of Z2M and saw something weird. Apparently it keeps sending an obscene amount of state updates to one particular innr light bulb, and I have honestly no idea why.
I have Adaptive Lighting, so maybe there’s some interconnection here why state updates are being sent, but why so frequently and how to “relax” the chatty Z2M, as it doesn’t seem to be doing the same to any other light bulbs even though those also fall under the Adaptive Lighting settings.
Any idea how to trouble shoot this? Here’s a log from Z2M
2023-08-20 11:52:54MQTT publish: topic 'zigbee2mqtt/innr_lampe_arbeitszimmer_w', payload '{"brightness":254,"color_mode":"color_temp","color_temp":200,"last_seen":"2023-08-20T11:52:55+02:00","linkquality":65,"power_on_behavior":null,"state":"ON"}'
debug 2023-08-20 11:52:56Received MQTT message on 'zigbee2mqtt/innr_lampe_arbeitszimmer_w/set' with data '{"state":"ON","transition":1.0,"brightness":254,"color_temp":188}'
debug 2023-08-20 11:52:56Publishing 'set' 'brightness' to 'innr_lampe_arbeitszimmer_w'
info 2023-08-20 11:52:56MQTT publish: topic 'zigbee2mqtt/innr_lampe_arbeitszimmer_w', payload '{"brightness":254,"color_mode":"color_temp","color_temp":200,"last_seen":"2023-08-20T11:52:56+02:00","linkquality":65,"power_on_behavior":null,"state":"ON"}'
debug 2023-08-20 11:52:56Publishing 'set' 'transition' to 'innr_lampe_arbeitszimmer_w'
debug 2023-08-20 11:52:56Publishing 'set' 'color_temp' to 'innr_lampe_arbeitszimmer_w'
debug 2023-08-20 11:52:56Requested color_temp 188 is lower than minimum supported 200, using minimum!
debug 2023-08-20 11:52:57Received MQTT message on 'zigbee2mqtt/innr_lampe_arbeitszimmer_w/set' with data '{"state":"ON","transition":1.0,"brightness":254,"color_temp":188}'
debug 2023-08-20 11:52:57Publishing 'set' 'brightness' to 'innr_lampe_arbeitszimmer_w'
info 2023-08-20 11:52:57MQTT publish: topic 'zigbee2mqtt/innr_lampe_arbeitszimmer_w', payload '{"brightness":254,"color_mode":"color_temp","color_temp":200,"last_seen":"2023-08-20T11:52:58+02:00","linkquality":65,"power_on_behavior":null,"state":"ON"}'
debug 2023-08-20 11:52:57Publishing 'set' 'transition' to 'innr_lampe_arbeitszimmer_w'
debug 2023-08-20 11:52:57Publishing 'set' 'color_temp' to 'innr_lampe_arbeitszimmer_w'
debug 2023-08-20 11:52:57Requested color_temp 188 is lower than minimum supported 200, using minimum!
debug 2023-08-20 11:52:59Received MQTT message on 'zigbee2mqtt/innr_lampe_arbeitszimmer_w/set' with data '{"state":"ON","transition":1.0,"brightness":254,"color_temp":188}'
debug 2023-08-20 11:52:59Publishing 'set' 'brightness' to 'innr_lampe_arbeitszimmer_w'
info 2023-08-20 11:52:59MQTT publish: topic 'zigbee2mqtt/innr_lampe_arbeitszimmer_w', payload '{"brightness":254,"color_mode":"color_temp","color_temp":200,"last_seen":"2023-08-20T11:52:59+02:00","linkquality":61,"power_on_behavior":null,"state":"ON"}'
debug 2023-08-20 11:52:59Publishing 'set' 'transition' to 'innr_lampe_arbeitszimmer_w'
debug 2023-08-20 11:52:59Publishing 'set' 'color_temp' to 'innr_lampe_arbeitszimmer_w'
debug 2023-08-20 11:52:59Requested color_temp 188 is lower than minimum supported 200, using minimum!
info 2023-08-20 11:52:59MQTT publish: topic 'zigbee2mqtt/innr_lampe_arbeitszimmer_w', payload '{"brightness":254,"color_mode":"color_temp","color_temp":200,"last_seen":"2023-08-20T11:52:59+02:00","linkquality":65,"power_on_behavior":null,"state":"ON"}'
debug 2023-08-20 11:53:00Received MQTT message on 'zigbee2mqtt/innr_lampe_arbeitszimmer_w/set' with data '{"state":"ON","transition":1.0,"brightness":254,"color_temp":188}'
debug 2023-08-20 11:53:00Publishing 'set' 'brightness' to 'innr_lampe_arbeitszimmer_w'
info 2023-08-20 11:53:00MQTT publish: topic 'zigbee2mqtt/innr_lampe_arbeitszimmer_w', payload '{"brightness":254,"color_mode":"color_temp","color_temp":200,"last_seen":"2023-08-20T11:53:01+02:00","linkquality":65,"power_on_behavior":null,"state":"ON"}'
debug 2023-08-20 11:53:00Publishing 'set' 'transition' to 'innr_lampe_arbeitszimmer_w'
debug 2023-08-20 11:53:00Publishing 'set' 'color_temp' to 'innr_lampe_arbeitszimmer_w'
debug 2023-08-20 11:53:00Requested color_temp 188 is lower than minimum supported 200, using minimum!
warning 2023-08-20 11:53:01Failed to ping 'innr_lampe_wohnzimmer_esstisch_5_rgbw' (attempt 1/1, Read 0xc498860000970116/1 genBasic(["zclVersion"], {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":true,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Timeout - 10560 - 1 - 216 - 0 - 1 after 10000ms))
debug 2023-08-20 11:53:02Received MQTT message on 'zigbee2mqtt/innr_lampe_arbeitszimmer_w/set' with data '{"state":"ON","transition":1.0,"brightness":254,"color_temp":188}'
debug 2023-08-20 11:53:02Publishing 'set' 'brightness' to 'innr_lampe_arbeitszimmer_w'
info 2023-08-20 11:53:02MQTT publish: topic 'zigbee2mqtt/innr_lampe_arbeitszimmer_w', payload '{"brightness":254,"color_mode":"color_temp","color_temp":200,"last_seen":"2023-08-20T11:53:02+02:00","linkquality":61,"power_on_behavior":null,"state":"ON"}'
debug 2023-08-20 11:53:02Publishing 'set' 'transition' to 'innr_lampe_arbeitszimmer_w'
debug 2023-08-20 11:53:02Publishing 'set' 'color_temp' to 'innr_lampe_arbeitszimmer_w'
debug 2023-08-20 11:53:02Requested color_temp 188 is lower than minimum supported 200, using minimum!
debug 2023-08-20 11:53:03Received MQTT message on 'zigbee2mqtt/innr_lampe_arbeitszimmer_w/set' with data '{"state":"ON","transition":1.0,"brightness":254,"color_temp":188}'
debug 2023-08-20 11:53:03Publishing 'set' 'brightness' to 'innr_lampe_arbeitszimmer_w'
info 2023-08-20 11:53:03MQTT publish: topic 'zigbee2mqtt/innr_lampe_arbeitszimmer_w', payload '{"brightness":254,"color_mode":"color_temp","color_temp":200,"last_seen":"2023-08-20T11:53:04+02:00","linkquality":65,"power_on_behavior":null,"state":"ON"}'
debug 2023-08-20 11:53:03Publishing 'set' 'transition' to 'innr_lampe_arbeitszimmer_w'
debug 2023-08-20 11:53:03Publishing 'set' 'color_temp' to 'innr_lampe_arbeitszimmer_w'
debug 2023-08-20 11:53:03Requested color_temp 188 is lower than minimum supported 200, using minimum!
info 2023-08-20 11:53:03MQTT publish: topic 'zigbee2mqtt/innr_lampe_arbeitszimmer_w', payload '{"brightness":254,"color_mode":"color_temp","color_temp":200,"last_seen":"2023-08-20T11:53:04+02:00","linkquality":61,"power_on_behavior":null,"state":"ON"}'
debug 2023-08-20 11:53:04Active device 'innr_lampe_wohnzimmer_esstisch_5_rgbw' was last seen '804.11' minutes ago.
debug 2023-08-20 11:53:05Received MQTT message on 'zigbee2mqtt/innr_lampe_arbeitszimmer_w/set' with data '{"state":"ON","transition":1.0,"brightness":254,"color_temp":188}'
debug 2023-08-20 11:53:05Publishing 'set' 'brightness' to 'innr_lampe_arbeitszimmer_w'
info 2023-08-20 11:53:05MQTT publish: topic 'zigbee2mqtt/innr_lampe_arbeitszimmer_w', payload '{"brightness":254,"color_mode":"color_temp","color_temp":200,"last_seen":"2023-08-20T11:53:05+02:00","linkquality":61,"power_on_behavior":null,"state":"ON"}'
debug 2023-08-20 11:53:05Publishing 'set' 'transition' to 'innr_lampe_arbeitszimmer_w'
debug 2023-08-20 11:53:05Publishing 'set' 'color_temp' to 'innr_lampe_arbeitszimmer_w'
debug 2023-08-20 11:53:05Requested color_temp 188 is lower than minimum supported 200, using minimum!
info 2023-08-20 11:53:05MQTT publish: topic 'zigbee2mqtt/innr_lampe_arbeitszimmer_w', payload '{"brightness":254,"color_mode":"color_temp","color_temp":200,"last_seen":"2023-08-20T11:53:05+02:00","linkquality":65,"power_on_behavior":null,"state":"ON"}'
debug 2023-08-20 11:53:06Received MQTT message on 'zigbee2mqtt/innr_lampe_arbeitszimmer_w/set' with data '{"state":"ON","transition":1.0,"brightness":254,"color_temp":188}'
debug 2023-08-20 11:53:06Publishing 'set' 'brightness' to 'innr_lampe_arbeitszimmer_w'
info 2023-08-20 11:53:06MQTT publish: topic 'zigbee2mqtt/innr_lampe_arbeitszimmer_w', payload '{"brightness":254,"color_mode":"color_temp","color_temp":200,"last_seen":"2023-08-20T11:53:07+02:00","linkquality":65,"power_on_behavior":null,"state":"ON"}'
debug 2023-08-20 11:53:06Publishing 'set' 'transition' to 'innr_lampe_arbeitszimmer_w'
debug 2023-08-20 11:53:06Publishing 'set' 'color_temp' to 'innr_lampe_arbeitszimmer_w'
debug 2023-08-20 11:53:06Requested color_temp 188 is lower than minimum supported 200, using minimum!
