Z2M - Philips Hue Tap Dial - Media Controls
Hi.
This blueprint supports controlling a media device and additional custom automations with a Philips Hue Tap Dial control. It is specific to Z2M.
Features of this blueprint:
  • Simple selection of a single media device to be controlled
  • User-specifiable volume steps - if your physical device uses a volume range other than 1-100, you can specify that range and this automation will scale incremental steps appropriately
  • The controller generates three rotation speed events : step, slow, and fast. This blueprint allows you to specify how many volume increments should be applied for each speed. You may, for example, set “step” to 1, slow to “3”, and fast to “5”. Because some volume ranges can result in rounding or truncation issues downstream of the automation, the blueprint allows these steps to be set as decimal values such as “1.5”
  • A short press of button 1 will toggle the play state of the target media device. Short presses of buttons 3 and 4 are, respectively, Previous Track and Next Track. The picture below illustrates this - apologies for the low quality of my homemade stickers
  • Short press of button 2 and long presses of all buttons are configurable automation sequences. Do whatever you like with them
blueprint:
# Media control via Philips Hue Tap Dial by gTunes
# Works only with Home Assistant and Zigbee2MQTT
# Version History:
#   - v 0.1 Dec 2023 : Initial version
# Based on earlier work by:
#      - https://community.home-assistant.io/t/z2m-ikea-symfonisk-gen2-e2123-media-control-v1-53/559523 Shawsky
#      - https://gist.github.com/erkr/a437ebcb98a2b5ba2deebabd02f5ffae Eric Kreuwels
#      - https://gist.github.com/alexwmaustin/2c25cfa1a0ade1ab9fc1ef0940289672 Alex Austin
  name: Z2M - Philips Hue Tap Dial Media Control
  description:
    'Control the selected media player (and any joined to it) with a Philips Hue Tap Dial controller via Zigbee2MQTT (Z2M)
    Supports volume control by rotating the dial
    A single press of Button 1 is Toggle Play / Pause
    Single presses of Buttons 3 and 4 are Previous Track and Next Track
    Single press of button 2 is configurable as are long presses of all buttons'
  domain: automation
  input:
    remote:
      description: The Philips Hue Tap Dial to use
      selector:
        device:
          integration: mqtt
          manufacturer: Philips
          model: Hue Tap dial switch (8719514440937/8719514440999)
          multiple: false
    base_topic:
      name: Zigbee2MQTT Base mqtt topic
      description: The base topic configured in Zigbee2MQTT. If you haven't changed this, leave the default here ("zigbee2mqtt")
      default: zigbee2mqtt
    media_player:
      description: The media player to control with this automation
      selector:
        entity:
          domain: media_player
          multiple: false
    volume_steps:
      name: Volume number of steps
      description: Controls the volume scale. Set this to the number of steps supported by your playback device
      default: 100
      selector:
        number:
          min: 5
          max: 100
          step: 1
          unit_of_measurement: "Num"
          mode: slider
    step_rotation_increments:
      name: "\"Step\" rotation volume increments"
      description: Number of volume increments for a "step" rotation event
      default: 1.0
      selector:
        number:
            min: 0.1
            max: 5.0
            step: 0.1
            mode: slider
    slow_rotation_increments:
      name: "\"Slow\" rotation volume increments"
      description: Number of volume increments for a "slow" rotation event
      default: 2
      selector:
        number:
            min: 0.1
            max: 5.0
            step: 0.1
            mode: slider
    fast_rotation_increments:
      name: "\"Fast\" rotation volume increments"
      description: Number of volume increments for a "fast" rotation event
      default: 3
      selector:
        number:
            min: 0.1
            max: 5.0
            step: 0.1
            mode: slider
    button_1_hold:
      name: Button 1 (Long)
      description: Action to run on a long press of Button 1
      default: []
      selector:
        action: {}
    button_2_short:
      name: Button 2 (Short)
      description: Action to run on a short press of Button 2
      default: []
      selector:
        action: {}
    button_2_hold:
      name: Button 2 (Long)
      description: Action to run on a long press of Button 2
      default: []
      selector:
        action: {}
    button_3_hold:
      name: Button 3 (Long)
      description: Action to run on a long press of Button 3
      default: []
      selector:
        action: {}
    button_4_hold:
      name: Button 4 (Long)
      description: Action to run on a long press of Button 4
      default: []
      selector:
        action: {}
mode: restart
max_exceeded: silent
trigger_variables:
  base_topic: !input base_topic
  controller: !input remote
  - platform: mqtt
    topic: "{{ base_topic }}/+/action"
  - variables:
      controllertopic: "{{ base_topic }}/{{ device_attr(controller, 'name') }}/action"
      player: !input 'media_player'
      steps: !input volume_steps
      stepsize: '{{ 1.0 / steps }}'
      stepmultiplier: {
          'dial_rotate_right_step' : !input step_rotation_increments,
          'dial_rotate_left_step' : !input step_rotation_increments,
          'dial_rotate_right_slow' : !input slow_rotation_increments,
          'dial_rotate_left_slow' : !input slow_rotation_increments,
          'dial_rotate_right_fast' : !input fast_rotation_increments,
          'dial_rotate_left_fast' : !input fast_rotation_increments
  - choose:
    - conditions:
      - "{{ trigger.payload != ''}}"
      - "{{ trigger.topic == controllertopic }}"
      sequence:
        - choose:
          ## Commands
          # Play / Pause
          - conditions: "{{ trigger.payload == 'button_1_press_release' }}"
            sequence:
            - service: media_player.media_play_pause
              entity_id: !input 'media_player'
          # Next Track
          - conditions: "{{ trigger.payload == 'button_4_press_release' }}"
            sequence:
            - service: media_player.media_next_track
          # Previous Track
          - conditions: "{{ trigger.payload == 'button_3_press_release' }}"
            sequence:
            - service: media_player.media_previous_track
          # Rotate Right (Volume Up)
          - conditions: "{{ trigger.payload in ['dial_rotate_right_step', 'dial_rotate_right_slow', 'dial_rotate_right_fast'] }}"
            sequence:
              - service: media_player.volume_set
                  entity_id: "{{ player }}"
                  volume_level: >-
                    {% set volume = state_attr(player, "volume_level") + (stepsize * stepmultiplier[trigger.payload]) %}
                    {{ 1.0 if volume > 1.0 else volume }}
          # Rotate Left (Volume Down)
          - conditions: "{{ trigger.payload in ['dial_rotate_left_step', 'dial_rotate_left_slow', 'dial_rotate_left_fast'] }}"
            sequence:
                    volume_level: >-
                      {% set volume = state_attr(player, "volume_level") - (stepsize * stepmultiplier[trigger.payload]) %}
                      {{ 0.0 if volume < 0.0 else volume }}
          ## Actions
          # Button 1 Long Press
          - conditions: "{{ trigger.payload == 'button_1_hold' }}"
            sequence: !input button_1_hold
          # Button 2 Short Press
          - conditions: "{{ trigger.payload == 'button_2_press_release' }}"
            sequence: !input button_2_short
          # Button 2 Long Press
          - conditions: "{{ trigger.payload == 'button_2_hold' }}"
            sequence: !input button_2_hold
          # Button 3 Long Press
          - conditions: "{{ trigger.payload == 'button_3_hold' }}"
            sequence: !input button_3_hold
          # Button 4 Long Press
          - conditions: "{{ trigger.payload == 'button_4_hold' }}"
            sequence: !input button_4_hold
Setup:
Select your device, adjust your MQTT base topic if necessary, the choose the media_player to control.
Choose volume steps, increments, etc. and configure the custom sequences as desired.
Thanks to the creators of previous blueprints from which this is derived. They’re credited in the blueprint.
Thank you very much. Please excuse the naive and slightly off topic question: What’s the default support of the Hue Tap Dial in HA and Z2M? I’m looking into purchasing a Tap Dial to control a light (rotate for dimming, buttons for on/off, color cycle, scene cycle) and am wondering if I can conveniently and easily configure all that myself in HA or if I’d need to spend hours fiddling with mqtt commands (which is something I never did before). Thanks!
Already replied to you in another thread, but this answers your specific question re support.
This site should be your go-to before buying any zigbee device - I suggest you bookmark it.
Thanks. I’m aware of that site and use it regularly. But even if a device exposes actions in mqtt this does not yet mean there’s a convenient way to configure the device in HA.
I will look into the blueprint you posted, thanks. I just think I’ve seen people mentioning last summer that a firmware update of the device broke compatibility with the currently available blueprints, which is why I assumed that a blueprint of 2022 does not work anymore for new devices (with a new firmware).
Don’t worry about it, it’ll work. I bought my Hue tap dials on Black Friday and used the blueprint around a month later with no issues whatsoever (Edit: even after updating the firmware on my test device).
Hi, I am trying to make this blueprint to work but it shows error message “missing input remote” even though I have written it correct. it’s not first blueprint I am using to control my Sonos speakers so I have eliminated user mistake :slight_smile: . I have latest 2024 version of HA and Z2M.
Trying to get this blueprint to work, i have a dial connected through z2m and it shows up in HA but not in the blueprint. ANyone know why?
can you post screenshot? maybe it’s the same as I have, I have typed in name of the dial tap manually as I have done on other blueprints.
I confirm that this is not working on the latest version of HA.
There is a filter applied for the input device selector.
I got it working by modifying the blueprint ‘input’ section to:
  input:
    remote:
      selector:
        device:
          filter:
            integration: mqtt
          multiple: false
I can confirm the input fix works for me, I created a gist with it here for easy importing: z2m-philips-hue-tap-dial-media-controls.yaml · GitHub
