After I updated today HO AND Z2M to the latest configuration I dont get the _action entity anymore for my ikea tradfri 5 button sensor. Any idea? I only see battery…
The automation complains " Error in describing trigger: e is undefined"
If i’m checking my entity I can’t find any name**_action**
Here’s my automation:
alias: 0_living_light_button_plastic_automation
description: ikea button
triggers:
- entity_id: sensor.0_living_light_button_plastic_action
to:
- toggle
- toggle_hold
- brightness_up_click
- brightness_down_click
- arrow_left_click
- arrow_right_click
- brightness_up_hold
- brightness_down_hold
- arrow_left_hold
- arrow_right_hold
- brightness_up_release
- brightness_down_release
- arrow_left_release
- arrow_right_release
trigger: state
actions:
- choose:
- conditions:
- condition: template
value_template: "{{ trigger.to_state.state == \"toggle\" }}"
sequence:
- target:
entity_id:
- light.0_living_light_front
- light.0_living_light_right
- light.0_living_light_left
- light.0_living_lights_tv
action: light.toggle
data: {}
- action: switch.toggle
metadata: {}
data: {}
entity_id: switch.0_living_steckdose_lampe
enabled: false
- conditions:
value_template: "{{ trigger.to_state.state == \"brightness_up_click\" }}"
sequence:
- target:
entity_id:
brightness_step_pct: 20
transition: 0.5
action: light.turn_on
- conditions:
value_template: "{{ trigger.to_state.state == \"brightness_down_click\" }}"
sequence:
- target:
entity_id:
brightness_step_pct: -20
transition: 0.5
- conditions:
value_template: "{{ trigger.to_state.state == \"arrow_left_click\" }}"
sequence:
- target:
entity_id:
color_temp: >-
{% if state_attr(var_light_entities.entity_id[0], "color_temp")
- 18 < 153 %}
{{ 153 }}
{% else %}
{{ state_attr(var_light_entities.entity_id[0], "color_temp") - 18 }}
{% endif %}
transition: 0.5
- conditions:
value_template: "{{ trigger.to_state.state == \"arrow_right_click\" }}"
sequence:
- target:
entity_id:
color_temp: >-
+ 18 > 500 %}
{{ 500 }}
{% else %}
{{ state_attr(var_light_entities.entity_id[0], "color_temp") + 18 }}
{% endif %}
transition: 0.5
- conditions:
value_template: "{{ trigger.to_state.state == \"toggle_hold\" }}"
sequence:
- target:
entity_id:
brightness: 254
color_temp: 400
- action: switch.turn_on
metadata: {}
data: {}
enabled: false
- conditions:
value_template: "{{ trigger.to_state.state == \"brightness_up_hold\" }}"
sequence:
- repeat:
while: []
sequence:
- target:
entity_id:
brightness_step_pct: 10
transition: 0.5
- delay:
milliseconds: 500
- conditions:
value_template: "{{ trigger.to_state.state == \"brightness_down_hold\" }}"
sequence:
- repeat:
while: []
sequence:
- target:
entity_id:
brightness_step_pct: -10
transition: 0.5
- delay:
milliseconds: 500
- conditions:
value_template: "{{ trigger.to_state.state == \"arrow_left_hold\" }}"
sequence:
- repeat:
while: []
sequence:
- target:
entity_id:
color_temp: >-
"color_temp") - 18 < 153 %}
{{ 153 }}
{% else %}
{% endif %}
transition: 0.5
- delay:
milliseconds: 500
- conditions:
value_template: "{{ trigger.to_state.state == \"arrow_right_hold\" }}"
sequence:
- repeat:
while: []
sequence:
- target:
entity_id:
color_temp: >-
"color_temp") + 18 > 500 %}
{{ 500 }}
{% else %}
{% endif %}
transition: 0.5
- delay:
milliseconds: 500
default: []
mode: restart
variables:
var_light_entities:
entity_id:
