This Blueprint is for using a IKEA STYRBAR (E2002) remote in your HA. You can set the lights to control and the actions to perform when the left or right button is clicked. When holding the up or down button, your lights will get dimmed.
Import:
Import:
Hi @Computerfreak14, would this work with ZHA integration?
I don’t seem to find an entity for my remote in the automation Editor
I am not too familiar with ZHA, so my solution might not be too good, if it even works, but i tried my best to make a version compatible with it. I can unfortunately not test it.
Sorry for taking so long to answer.
Import:
Hi, I integrated your second Blueprint. After clicking on save nothing happens and no automation is generated.
Thx for your help
Thanks for the support @Computerfreak14 the blueprint did not work, but when reading it, it gave me a good idea on what to do.
I kind of have the remote working now, but not all buttons are fully functional. I saw your events and they were similar to the ones I was getting through ZHA, but not identical. So I replaced those and that did the trick. You can get the needed info from listening to zha_event in developer tools → event, then just press and long press each button to see the commands for each of them, the mapping I got looks like this:
As you can see you get actually 2 commands when long pressing up and down. So you can get 4 different functions with this remote:
1.- Press Up
2.- Press Down
3.- Long Press Up
4.- Long Press Down
To set up an automation (I have one for each of the above) it looks something like this:
alias: Styrbar test Up
description: ''
- event_data:
device_ieee: "device_ieee from zha_event"
unique_id: "unique id from zha_event"
device_id: "device id from zha_event"
command: 'on'
args: []
platform: event
event_type: zha_event
condition: []
- device_id: "device you want to trigger, in this case a light"
domain: light
entity_id: "entity of device you want to trigger"
type: brightness_increase
mode: single
You must only change the command and condition value for each button.
The only issue I have left is that the side buttons don’t seem to trigger any event o a simple press, and the battery repoting seems to be half of the actual battery left.
Hope this helps
Thanks so much for the tip to “debug” listening on zha_event!
I got those response with left and right buttons (args are differents):
With right
"event_type": "zha_event",
"data": {
"device_ieee": "80:4b:50:ff:fe:9f:d9:2b",
"unique_id": "80:4b:50:ff:fe:9f:d9:2b:1:0x0005",
"device_id": "79bf28217e31c5bf5542d83b678a224e",
"endpoint_id": 1,
"cluster_id": 5,
"command": "press",
"args": [
256,
13,
0
"origin": "LOCAL",
"time_fired": "2021-09-12T23:35:21.968518+00:00",
"context": {
"id": "c692698f174e394ad20d050aeaf3d459",
"parent_id": null,
"user_id": null
With left
"data": {
"endpoint_id": 1,
"cluster_id": 5,
"command": "press",
"args": [
257,
13,
0
"origin": "LOCAL",
"time_fired": "2021-09-12T23:37:26.803999+00:00",
"context": {
"id": "b75b210654afa713ac7e661f7f088fd3",
"parent_id": null,
"user_id": null
I get no response or event at all when pressing left and right buttons (only when long pressing)…
I am using ZHA with a Conbee II stick.
Did they work from the start with you @Slobadx?
Yes, I got the event response throught ZHA without any previus configuration but I am using CC2531
Hey guys,
thanks for sharing,
here is ZHA modified version of IKEA STYRBAR remote.
Added left/right button long press support.
Feel free to share and use as own blueprint.
blueprint:
name: Ikea Styrbar Remote
description: Control your lights with the IKEA STYRBAR remote. You can also set
actions for the left and right button.
domain: automation
input:
remote:
description: IKEA Styrbar remote to use
selector:
device:
integration: zha
manufacturer: IKEA of Sweden
entity:
domain: sensor
target_light:
description: The lights you want to control with the remote
selector:
entity:
domain: light
button_left:
description: Action to run on left button press short
default: []
selector:
action: {}
button_right:
description: Action to run on right button press short
default: []
selector:
action: {}
button_left_hold:
name: Left button hold
description: Action to run on left button press long,
action is stopped when button is released.
default: []
selector:
action: {}
button_right_hold:
name: Right button hold
description: Action to run on right button press long,
default: []
selector:
action: {}
brightness:
description: The brightness you want your lights to be when turning them on
default: 100
selector:
number:
min: 0.0
max: 100.0
mode: slider
step: 1.0
unit_of_measurement: '%'
force_brightness:
name: Force Brightness
description: Force the above set brightness when turning on the lamps?
default: false
selector:
boolean: {}
source_url: https://raw.githubusercontent.com/Computerfreak14/Z2M-Styrbar-remote-blueprint/experimental-ZHA/Z2M-IKEA-STYRBAR-remote.yaml
- platform: event
event_data:
device_id: !input 'remote'
- variables:
command: '{{ trigger.event.data.command }}'
dataargs: '{{ trigger.event.data.args }}'
- choose:
- conditions: '{{ command == ''on'' }}'
sequence:
- choose:
- conditions: '{{ force_brightness }}'
sequence:
- service: light.turn_on
target: !input 'target_light'
transition: 1
brightness_pct: !input 'brightness'
default:
transition: 1
- conditions: '{{ command == ''off'' }}'
sequence:
- service: light.turn_off
- conditions: '{{ command == ''move'' }}'
sequence:
- repeat:
until: '{{ command == ''stop'' }}'
sequence:
brightness_step_pct: -10
transition: 1
- delay: '1'
- conditions: '{{ command == ''move_with_on_off'' }}'
sequence:
- repeat:
sequence:
brightness_step_pct: 10
transition: 1
- delay: '1'
- conditions:
- '{{ command == ''press'' }}'
- '{{ dataargs[0] == 257 }}'
sequence: !input 'button_left'
- conditions:
- '{{ dataargs[0] == 256 }}'
sequence: !input 'button_right'
- conditions:
- '{{ command == ''hold'' }}'
- '{{ dataargs[0] == 3329 }}'
sequence:
- repeat:
until: '{{ command == ''release'' }}'
sequence: !input 'button_left_hold'
- conditions:
- '{{ dataargs[0] == 3328 }}'
sequence:
- repeat:
sequence: !input 'button_right_hold'
mode: restart
max_exceeded: silent
Made an account to thank you for this!
Works great with ZHA with a conbeeII stick
I’ve added the blueprint from the first post & then overwrote it manually with the one from @se3
Works like a charm
Any chance of including the Left Hold and Right Hold on the zigbee2mqtt blueprint? I tried adapting but made a mess of it :>
Hello, will it be possible to use this with deconz/phoscon integration?
Hi @r100gs , it’s working with deCONZ.
I have question for @Computerfreak14: how can I increase the time for changing the brightness?
Instead of changing the brightness in 1 sec, to do it in 3 seconds (for example).
you can set it in zigbee2mqtt addon > you device > setting (specific) > transition
hi @nicolae.fratila,
Is there any step before adding the blueprint to do in deconz/phoscon to add the remote ?
Thanks in advance.
You don’t have to do anything in deCONZ before adding the blueprint. I just set the automation based on blueprint
Hi @nicolae.fratila ,
thanks for your help.
However i tried and added the blueprint, tried to create an automation without doing anything more, but it asks for the “action entity of your Styrbar remote”, i dont have any entity for the remote.
Then i tried to add the remote on deconz, selecting the IKEA products → others, and it was added, but only have the battery entity .
is this normal or theres any other step that i have to do ?
Thanks in advance for your help.
HI,
I just run across this template and it’s exactly what I was looking for. but I can’t seem to get it working.
The state variable step is giving me an error… Anybody who know what to do about it?
@Computerfreak14 Thank you for creating this BluePrint. Seems it is not possible to import this BluePrint anymore.
HA information:
Home Assistant 2022.11.4
Supervisor 2022.11.2
Operating System 9.3
Frontend 20221108.0 - latest
Error I get while importing
I’m having the same problem, did you find out how to solve? Thank you
