Overview
An easy way for using various zigbee wireless switches
Prerequisites
- Ensure all wireless switches are connected to zigbee2mqtt.
Supported Device - (confirmed working)
Tuya
Sihas
- Wireless 4gang - SBM300ZC4
Aqara
Unidentified devices;
- Even if the device operation cannot be confirmed, it can still be used without modification if triggered by states such as single / x_single / button_x_single in the action sensor.
(x = 1~4, the numbers of buttons you can tap range from 1 to 4)
User Manual
- Select the sensor with the entity ID = sensor.[THE NAME OF THE DEVICE YOU PAIRED]_action; from the dropdown for your desired switch device.
- Create automation actions. Done!
NOTE
- The RELEASE action of all buttons DOES NOT WORK
- The actions of AQARA MINI should only be placed in 1_x_action.
(x = single, double, hold) - The BOTH CLICK action of Aqara T1 should be placed in 3_x_action.
Blueprint
blueprint:
name: Various Zigbee Wireless Switch
description:
Tuya - [TS0044](https://www.zigbee2mqtt.io/devices/TS0044.html)
Sihas - Wireless 4gang - [SBM300ZC4](https://www.zigbee2mqtt.io/devices/SBM300ZC4.html#shinasystem-sbm300zc4)
Aqara - Wireless remote switch T1 (double rocker) - [WXKG04LM](https://www.zigbee2mqtt.io/devices/WXKG04LM.html#aqara-wxkg04lm)
/ Wireless mini switch t1 - [WXKG13LM](https://www.zigbee2mqtt.io/devices/WXKG13LM.html#aqara-wxkg13lm)
User Manual
1. Ensure all wireless switches are connected to zigbee2mqtt.
2. Select the sensor with the entity ID = sensor.[THE NAME OF THE DEVICE YOU PAIRED]_action; from the dropdown for your desired switch device.
3. Create automation actions. Done!
NOTE!
* The RELEASE action of all buttons DOES NOT WORK
* The actions of AQARA MINI should only be placed in 1_*_action. (* single, double, hold)
* The BOTH CLICK action of Aqara T1 should be placed in 3_*_action. (* single, double, hold)
For debugging note;
* If you want to know the details about the button action states, go to "/config/blueprints/automation/kkqq9320/various_zigbee_wireless_switch.yaml"
#Working trigger Actions backup
# Tuya(TS0044)
# 1_single
# 1_double
# 1_hold
# Sihas
# 1_single
# 1_double
# 1_long
# Aqara mini
# single
# double
# hold
# Aqara double rocker
# button_1_single
# button_1_double
# button_1_hold
domain: automation
input:
action_sensor:
description: Zigbee2mqtt action sensor
selector:
entity:
integration: mqtt
domain:
- sensor
multiple: false
1_single_action:
description: Any Button, (*Mini Sholud be here)
default: []
selector:
action: {}
1_double_action:
default: []
selector:
action: {}
1_hold_action:
default: []
selector:
action: {}
2_single_action:
description: Tuya, T1, Sihas
default: []
selector:
action: {}
2_double_action:
default: []
selector:
action: {}
2_hold_action:
default: []
selector:
action: {}
3_single_action:
description: Tuya, T1, Sihas (*T1's Both action Sholud be here)
default: []
selector:
action: {}
3_double_action:
default: []
selector:
action: {}
3_hold_action:
default: []
selector:
action: {}
4_single_action:
description: Tuya, Sihas
default: []
selector:
action: {}
4_double_action:
default: []
selector:
action: {}
4_hold_action:
default: []
selector:
action: {}
mode: parallel
max: 100
max_exceeded: silent
platform: state
entity_id: !input action_sensor
- variables:
action: '{{ trigger.to_state.state }}'
- choose:
- conditions: "{{ action in ['1_single', 'single', 'button_1_single'] }}"
sequence: !input 1_single_action
- conditions: "{{ action in ['1_double', 'double', 'button_1_double'] }}"
sequence: !input 1_double_action
- conditions: "{{ action in ['1_hold', '1_long', 'hold', 'button_1_hold'] }}"
sequence: !input 1_hold_action
- conditions: "{{ action in ['2_single', 'button_2_single'] }}"
sequence: !input 2_single_action
- conditions: "{{ action in ['2_double', 'button_2_double'] }}"
sequence: !input 2_double_action
- conditions: "{{ action in ['2_hold', '2_long', 'button_2_hold'] }}"
sequence: !input 2_hold_action
- conditions: "{{ action in ['3_single', 'button_3_single'] }}"
sequence: !input 3_single_action
- conditions: "{{ action in ['3_double', 'button_3_double'] }}"
sequence: !input 3_double_action
- conditions: "{{ action in ['3_hold', '3_long', 'button_3_hold'] }}"
sequence: !input 3_hold_action
- conditions: "{{ action in ['4_single', 'button_4_single'] }}"
sequence: !input 4_single_action
- conditions: "{{ action in ['4_double', 'button_4_double'] }}"
sequence: !input 4_double_action
- conditions: "{{ action in ['4_hold', '4_long'] }}"
sequence: !input 4_hold_action
