Hi there!
I want to switch my fine working Z2M setup, which is currently operated by a (Sonoff Zigbee 3.0) USB device to a LAN coodinator.
The LAN coordinator is also a Sonoff Zigbee 3.0 USB connected via Serial Interface with an ESP32 ETH01, operating with Tasmota as TCP bridge.
My config looks like this:
data_path: /config/zigbee2mqtt
socat:
enabled: false
master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
options: "-d -d"
log: false
mqtt:
base_topic: zigbee2mqtt
user: xxx
password: xxx
server: mqtt://192.168.1.116:1883
serial:
port: 'tcp://192.168.1.199:6638'
The weired thing: Everything wokted teporatily with my LAN coordinator, but after changing the TCP bridge (ESP32ETH) from wifi to LAN I get an error after starting Z2M:
[23:00:37] INFO: Preparing to start...
[23:00:37] INFO: Socat not enabled
[23:00:39] INFO: Starting Zigbee2MQTT...
Zigbee2MQTT:info 2023-04-22 23:00:45: Logging to console and directory: '/config/zigbee2mqtt/log/2023-04-22.23-00-45' filename: log.txt
Zigbee2MQTT:info 2023-04-22 23:00:45: Starting Zigbee2MQTT version 1.30.3 (commit #unknown)
Zigbee2MQTT:info 2023-04-22 23:00:45: Starting zigbee-herdsman (0.14.103)
Zigbee2MQTT:error 2023-04-22 23:07:32: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2023-04-22 23:07:32: Failed to start zigbee
Zigbee2MQTT:error 2023-04-22 23:07:32: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
Zigbee2MQTT:error 2023-04-22 23:07:32: Exiting...
Zigbee2MQTT:error 2023-04-22 23:07:33: TypeError: Cannot read properties of undefined (reading 'payload')
at AdapterNvMemory.writeExtendedTableEntry (/app/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/adapter-nv-memory.ts:211:27)
at AdapterNvMemory.writeTable (/app/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/adapter-nv-memory.ts:321:17)
at AdapterBackup.restoreBackup (/app/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/adapter-backup.ts:349:13)
at ZnpAdapterManager.beginRestore (/app/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/manager.ts:299:9)
at ZnpAdapterManager.start (/app/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/manager.ts:80:17)
at Controller.start (/app/node_modules/zigbee-herdsman/src/controller/controller.ts:132:29)
at Zigbee.start (/app/lib/zigbee.ts:58:27)
at Controller.start (/app/lib/con
Evry help is highly appreciated. Thanks!
