I can’t start the Z2M with poe Coordinator.
I’ve a zha with usb dongle, and want a second network on a different floor.
I thought about installation of Z2m with poe, but it doesn’t work.
I’ve attached the photos.
What adapter ?
What errors do you get in Zigbee2MQTT ?
Looks like you use the Zigbee2MQTT add-on.
under serial, remove
serial:
and
advanced:
transmit_power: 20
and move the remaining to the left.
Seems Zigbee2MQTT does not want to start because you have an invalid backup in its directory.
And please post error logs as text, those screenshots are very difficult to read.
at start (/app/index.js:107:5)
[05:39:43] INFO: Preparing to start…
[05:39:43] INFO: Socat not enabled
[05:39:45] INFO: Starting Zigbee2MQTT…
[2024-05-24 05:39:51] info: z2m: Logging to console, file (filename: log.log)
[2024-05-24 05:39:51] info: z2m: Starting Zigbee2MQTT version 1.37.1 (commit #unknown)
[2024-05-24 05:39:51] info: z2m: Starting zigbee-herdsman (0.46.6)
[2024-05-24 05:39:51] warning: zh:ezsp: Deprecated driver ‘ezsp’ currently in use, ‘ember’ will become the officially supported EmberZNet driver in next release. If using Zigbee2MQTT see Improved Ember (EZSP) driver (experimental) · Koenkk/zigbee2mqtt · Discussion #21462 · GitHub
[2024-05-24 05:39:55] error: zh:ezsp:ezsp: Failure to init network
[2024-05-24 05:39:55] error: z2m: Error while starting zigbee-herdsman
[2024-05-24 05:39:55] error: z2m: Failed to start zigbee
[2024-05-24 05:39:55] error: z2m: Check Zigbee2MQTT fails to start | Zigbee2MQTT for possible solutions
[2024-05-24 05:39:55] error: z2m: Exiting…
[2024-05-24 05:39:55] error: z2m: Error: This open coordinator backup format not for EZSP adapter
at EZSPAdapterBackup.getStoredBackup (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/adapter/backup.ts:101:23)
at Driver.needsToBeRestore (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/driver.ts:903:24)
at Driver.startup (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/driver.ts:219:29)
at Controller.start (/app/node_modules/zigbee-herdsman/src/controller/controller.ts:124:29)
at Zigbee.start (/app/lib/zigbee.ts:62:27)
at Controller.start (/app/lib/controller.ts:109:27)
[05:39:58] INFO: Preparing to start…
[05:39:59] INFO: Socat not enabled
[05:40:00] INFO: Starting Zigbee2MQTT…
[2024-05-24 05:40:06] info: z2m: Logging to console, file (filename: log.log)
[2024-05-24 05:40:06] info: z2m: Starting Zigbee2MQTT version 1.37.1 (commit #unknown)
[2024-05-24 05:40:06] info: z2m: Starting zigbee-herdsman (0.46.6)
[2024-05-24 05:40:07] warning: zh:ezsp: Deprecated driver ‘ezsp’ currently in use, ‘ember’ will become the officially supported EmberZNet driver in next release. If using Zigbee2MQTT see Improved Ember (EZSP) driver (experimental) · Koenkk/zigbee2mqtt · Discussion #21462 · GitHub
[2024-05-24 05:40:10] error: zh:ezsp:ezsp: Failure to init network
[2024-05-24 05:40:10] error: z2m: Error while starting zigbee-herdsman
[2024-05-24 05:40:10] error: z2m: Failed to start zigbee
[2024-05-24 05:40:10] error: z2m: Check Zigbee2MQTT fails to start | Zigbee2MQTT for possible solutions
[2024-05-24 05:40:10] error: z2m: Exiting…
[2024-05-24 05:40:10] error: z2m: Error: This open coordinator backup format not for EZSP adapter
[05:40:13] INFO: Preparing to start…
[05:40:14] INFO: Socat not enabled
[05:40:16] INFO: Starting Zigbee2MQTT…
[2024-05-24 05:40:21] info: z2m: Logging to console, file (filename: log.log)
[2024-05-24 05:40:21] info: z2m: Starting Zigbee2MQTT version 1.37.1 (commit #unknown)
[2024-05-24 05:40:21] info: z2m: Starting zigbee-herdsman (0.46.6)
[2024-05-24 05:40:22] warning: zh:ezsp: Deprecated driver ‘ezsp’ currently in use, ‘ember’ will become the officially supported EmberZNet driver in next release. If using Zigbee2MQTT see Improved Ember (EZSP) driver (experimental) · Koenkk/zigbee2mqtt · Discussion #21462 · GitHub
[2024-05-24 05:40:25] error: zh:ezsp:ezsp: Failure to init network
[2024-05-24 05:40:25] error: z2m: Error while starting zigbee-herdsman
[2024-05-24 05:40:25] error: z2m: Failed to start zigbee
[2024-05-24 05:40:25] error: z2m: Check Zigbee2MQTT fails to start | Zigbee2MQTT for possible solutions
[2024-05-24 05:40:25] error: z2m: Exiting…
[2024-05-24 05:40:25] error: z2m: Error: This open coordinator backup format not for EZSP adapter
[05:40:28] INFO: Preparing to start…
[05:40:28] INFO: Socat not enabled
[05:40:30] INFO: Starting Zigbee2MQTT…
[2024-05-24 05:40:36] info: z2m: Logging to console, file (filename: log.log)
[2024-05-24 05:40:36] info: z2m: Starting Zigbee2MQTT version 1.37.1 (commit #unknown)
[2024-05-24 05:40:36] info: z2m: Starting zigbee-herdsman (0.46.6)
[2024-05-24 05:40:36] warning: zh:ezsp: Deprecated driver ‘ezsp’ currently in use, ‘ember’ will become the officially supported EmberZNet driver in next release. If using Zigbee2MQTT see Improved Ember (EZSP) driver (experimental) · Koenkk/zigbee2mqtt · Discussion #21462 · GitHub
[2024-05-24 05:40:40] error: zh:ezsp:ezsp: Failure to init network
[2024-05-24 05:40:40] error: z2m: Error while starting zigbee-herdsman
[2024-05-24 05:40:40] error: z2m: Failed to start zigbee
[2024-05-24 05:40:40] error: z2m: Check Zigbee2MQTT fails to start | Zigbee2MQTT for possible solutions
[2024-05-24 05:40:40] error: z2m: Exiting…
[2024-05-24 05:40:40] error: z2m: Error: This open coordinator backup format not for EZSP adapter
[05:40:44] INFO: Preparing to start…
[05:40:44] INFO: Socat not enabled
[05:40:46] INFO: Starting Zigbee2MQTT…
[2024-05-24 05:40:52] info: z2m: Logging to console, file (filename: log.log)
[2024-05-24 05:40:52] info: z2m: Starting Zigbee2MQTT version 1.37.1 (commit #unknown)
[2024-05-24 05:40:52] info: z2m: Starting zigbee-herdsman (0.46.6)
[2024-05-24 05:40:52] warning: zh:ezsp: Deprecated driver ‘ezsp’ currently in use, ‘ember’ will become the officially supported EmberZNet driver in next release. If using Zigbee2MQTT see Improved Ember (EZSP) driver (experimental) · Koenkk/zigbee2mqtt · Discussion #21462 · GitHub
[2024-05-24 05:40:56] error: zh:ezsp:ezsp: Failure to init network
[2024-05-24 05:40:56] error: z2m: Error while starting zigbee-herdsman
[2024-05-24 05:40:56] error: z2m: Failed to start zigbee
[2024-05-24 05:40:56] error: z2m: Check Zigbee2MQTT fails to start | Zigbee2MQTT for possible solutions
[2024-05-24 05:40:56] error: z2m: Exiting…
[2024-05-24 05:40:56] error: z2m: Error: This open coordinator backup format not for EZSP adapter
Remove the backup in its directory.
How can I do it…?
