today I upgraded the Raspberry Pi HA OS to 13.2.
Afterwards, Z2M with the Sonoff Dongle E stopped working and I have no idea how to make it work again.
Configuration as follows:
The firmware for the dongle is on the latest current version (I think it’s 7.4.4). That firmware worked fine for a few weeks now, but the whole thing stopped working after upgrading HA OS to 13.2.
I reflashed the most current firmware, rebootet my Pi4, removed the USB extension cable to connect the Sonoff directly to the Pi, also used a different USB slot… Nothing works. I always get this:
[18:58:27] INFO: Preparing to start...
[18:58:27] INFO: Socat not enabled
[18:58:30] INFO: Starting Zigbee2MQTT...
Starting Zigbee2MQTT without watchdog.
[2024-10-23 18:58:36] info: z2m: Logging to console, file (filename: log.log)
[2024-10-23 18:58:36] info: z2m: Starting Zigbee2MQTT version 1.40.2 (commit #unknown)
[2024-10-23 18:58:36] info: z2m: Starting zigbee-herdsman (2.1.3)
[2024-10-23 18:58:37] info: zh:ember: Using default stack config.
[2024-10-23 18:58:37] info: zh:ember: ======== Ember Adapter Starting ========
[2024-10-23 18:58:37] info: zh:ember:ezsp: ======== EZSP starting ========
[2024-10-23 18:58:37] info: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2024-10-23 18:58:37] info: zh:ember:uart:ash: RTS/CTS config is off, enabling software flow control.
[2024-10-23 18:58:37] info: zh:ember:uart:ash: Serial port opened
[2024-10-23 18:58:37] info: zh:ember:uart:ash: ======== ASH starting ========
[2024-10-23 18:58:40] info: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2024-10-23 18:58:40] info: zh:ember:uart:ash: ======== ASH starting ========
[2024-10-23 18:58:42] info: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2024-10-23 18:58:42] info: zh:ember:uart:ash: ======== ASH starting ========
[2024-10-23 18:58:45] info: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2024-10-23 18:58:45] info: zh:ember:uart:ash: ======== ASH starting ========
[2024-10-23 18:58:47] info: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2024-10-23 18:58:47] info: zh:ember:uart:ash: ======== ASH starting ========
[2024-10-23 18:58:50] error: z2m: Error while starting zigbee-herdsman
[2024-10-23 18:58:50] error: z2m: Failed to start zigbee
[2024-10-23 18:58:50] error: z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
[2024-10-23 18:58:50] error: z2m: Exiting...
[2024-10-23 18:58:50] error: z2m: Error: Failed to start EZSP layer with status=HOST_FATAL_ERROR.
at EmberAdapter.initEzsp (/app/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:684:19)
at EmberAdapter.start (/app/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:1583:24)
at Controller.start (/app/node_modules/zigbee-herdsman/src/controller/controller.ts:137:29)
at Zigbee.start (/app/lib/zigbee.ts:69:27)
at Controller.start (/app/lib/controller.ts:161:27)
at start (/app/index.js:154:5)
Any ideas? I am out of ideas…
