My SLZB-06 died so i have replaced it.
Swapped my config for the new adapters IP and now it wont start… I fear i’ve also updated so it might be a firmware issue, but i’ve tried a couple of different versions without success.
Can someone help? It’s very dark in here at the moment
[15:35:25] INFO: Preparing to start...
[15:35:26] INFO: Socat not enabled
[15:35:27] INFO: Starting Zigbee2MQTT...
Starting Zigbee2MQTT without watchdog.
[2024-07-14 15:35:34] info: z2m: Logging to console, file (filename: log.log)
[2024-07-14 15:35:34] info: z2m: Starting Zigbee2MQTT version 1.39.0 (commit #unknown)
[2024-07-14 15:35:34] info: z2m: Starting zigbee-herdsman (0.50.1)
[2024-07-14 15:35:34] info: zh:ember: Using default stack config.
[2024-07-14 15:35:34] info: zh:ember: ======== Ember Adapter Starting ========
[2024-07-14 15:35:34] info: zh:ember:ezsp: ======== EZSP starting ========
[2024-07-14 15:35:34] info: zh:ember:uart:ash: ======== ASH NCP reset ========
[2024-07-14 15:35:34] info: zh:ember:uart:ash: Socket ready
[2024-07-14 15:35:34] info: zh:ember:uart:ash: ======== ASH starting ========
[2024-07-14 15:35:37] info: zh:ember:uart:ash: ======== ASH NCP reset ========
[2024-07-14 15:35:37] info: zh:ember:uart:ash: ======== ASH starting ========
[2024-07-14 15:35:39] info: zh:ember:uart:ash: ======== ASH NCP reset ========
[2024-07-14 15:35:39] info: zh:ember:uart:ash: ======== ASH starting ========
[2024-07-14 15:35:42] info: zh:ember:uart:ash: ======== ASH NCP reset ========
[2024-07-14 15:35:42] info: zh:ember:uart:ash: ======== ASH starting ========
[2024-07-14 15:35:44] info: zh:ember:uart:ash: ======== ASH NCP reset ========
[2024-07-14 15:35:44] info: zh:ember:uart:ash: ======== ASH starting ========
[2024-07-14 15:35:47] error: z2m: Error while starting zigbee-herdsman
[2024-07-14 15:35:47] error: z2m: Failed to start zigbee
[2024-07-14 15:35:47] error: z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
[2024-07-14 15:35:47] error: z2m: Exiting...
[2024-07-14 15:35:47] error: z2m: Error: Failed to start EZSP layer with status=HOST_FATAL_ERROR.
at EmberAdapter.initEzsp (/app/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:889:19)
at EmberAdapter.start (/app/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:2722:24)
at Controller.start (/app/node_modules/zigbee-herdsman/src/controller/controller.ts:129:29)
at Zigbee.start (/app/lib/zigbee.ts:63:27)
at Controller.start (/app/lib/controller.ts:139:27)
at start (/app/index.js:154:5)
Config is:
serial:
# Location of SLZB-06
port: tcp://192.168.14.72:6631
baudrate: 115200
adapter: ember
