Z2M Xiaomi Mi wireless switch (WXKG01LM) Blueprint
Blueprint for Xiaomi Mi wireless switch WXKG01LM working with Zigbee2MQTT 2.0.0-1.
blueprint:
  name: Xiaomi Mi wireless remote switch WXKG01LM (Zigbee MQTT Trigger)
  description: "Controller automation for executing any kind of action triggered by the provided Xiaomi Mi WXKG01LM switch. \n\n
    You can have different actions on single press, double press, triple press, quadruple press, many press, hold and release. \n\n
    Make sure to manually create a separate Text Helper per switch device and define its entity in the automation. It's used
    to store the last controller event to filter possible empty events."
  domain: automation
  input:
    mqtt_topic:
      description: Topic of the Xiaomi Mi WXKG01LM
      default: zigbee2mqtt/<device name>
    helper_last_controller_event:
      name: (Required) Helper - Last Controller Event
      description: Input Text used to store the last event fired by the controller.
        You will need to manually create a text input Helper entity for this.
      default: ''
      selector:
        entity:
          domain:
          - input_text
          multiple: false
    single:
      name: Single button press
      description: Action to run
      default: []
      selector:
        action: {}
    double:
      name: Double button press
      default: []
      selector:
        action: {}
    triple:
      name: Triple button press
      default: []
      selector:
        action: {}
    quadruple:
      name: Quadruple button press
      default: []
      selector:
        action: {}
    many:
      name: Many button press
      default: []
      selector:
        action: {}
    hold:
      name: Hold of button
      default: []
      selector:
        action: {}
    release:
      name: Release of button
      default: []
      selector:
        action: {}
mode: queued
max_exceeded: silent
- platform: mqtt
  topic: !input mqtt_topic
condition:
- condition: template
  value_template: '{{ trigger.payload_json.action != '''' }}'
- variables:
    helper_last_controller_event: !input helper_last_controller_event
    command: '{{ trigger.payload_json.action }}'
    prev_command: '{{ states(helper_last_controller_event) }}'
- service: input_text.set_value
    entity_id: !input helper_last_controller_event
    value: '{{ command }}'
- choose:
  - conditions:
    - '{{ command == "single" }}'
    sequence: !input single
  - conditions:
    - '{{ command == "double" }}'
    sequence: !input double
  - conditions:
    - '{{ command == "triple" }}'
    sequence: !input triple
  - conditions:
    - '{{ command == "quadruple" }}'
    sequence: !input quadruple
  - conditions:
    - '{{ command == "many" }}'
    sequence: !input many
  - conditions:
    - '{{ command == "hold" }}'
    sequence: !input hold
  - conditions:
    - '{{ command == "release" }}'
    sequence: !input release
Link to Z2M Aqara wireless remote double switch (WXKG02LM_rev2) Blueprint
I have a few of these buttons and since a couple of days ago, they’ve stopped reporting single click. Whenever I do a single click, the LogBook for the entity is reporting it as ‘long’.
I’ve read in another blueprint that setting the hold time can assist with the issue, however it is setup for ZHA whereas I am using Zigbee2MQTT. Would you know how to update your blueprint so that the hold time can be adjusted?
