I have a zigbee adapter connected to my Pi4 ModelB 4GB.
Here are the logs:
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] socat.sh: executing...
[14:45:05] INFO: Socat not enabled, marking service as down
[cont-init.d] socat.sh: exited 0.
[cont-init.d] zigbee2mqtt.sh: executing...
[14:45:06] INFO: MQTT available, fetching server detail ...
[14:45:06] INFO: MQTT server settings not configured, trying to auto-discovering ...
[14:45:07] INFO: Configuring 'mqtt://core-mosquitto:1883' mqtt server
[14:45:07] INFO: MQTT credentials not configured, trying to auto-discovering ...
[14:45:07] INFO: Configuring'addons' mqtt user
[14:45:07] INFO: Previous config file found, checking backup
[14:45:07] INFO: Creating backup config in '/config/zigbee2mqtt/.configuration.yaml.bk'
[14:45:07] INFO: Adjusting Zigbee2mqtt core yaml config with add-on quirks ...
[cont-init.d] zigbee2mqtt.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[14:45:09] INFO: Handing over control to Zigbee2mqtt Core ...
> [email protected] start
> node index.js
Zigbee2MQTT:warn 2021-12-20 14:45:16: `permit_join` set to `true` in configuration.yaml.
Zigbee2MQTT:warn 2021-12-20 14:45:16: Allowing new devices to join.
Zigbee2MQTT:warn 2021-12-20 14:45:16: Set `permit_join` to `false` once you joined all devices.
Zigbee2MQTT:warn 2021-12-20 14:45:16: Using experimental new availability feature
Zigbee2MQTT:error 2021-12-20 14:58:31: Adapter disconnected, stopping
Zigbee2MQTT:error 2021-12-20 14:58:31: Failed to stop Zigbee2MQTT
[14:58:32] INFO: Handing over control to Zigbee2mqtt Core ...
> node index.js
Zigbee2MQTT:error 2021-12-20 14:58:38: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2021-12-20 14:58:38: Failed to start zigbee
Zigbee2MQTT:error 2021-12-20 14:58:38: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
Zigbee2MQTT:error 2021-12-20 14:58:38: Exiting...
Zigbee2MQTT:error 2021-12-20 14:58:38: Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0'
at SerialPort.<anonymous> (/app/node_modules/zigbee-herdsman/src/adapter/z-stack/znp/znp.ts:146:28)
at SerialPort._error (/app/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:198:14)
at /app/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:242:12
[14:58:38] INFO: Handing over control to Zigbee2mqtt Core ...
> node index.js
Zigbee2MQTT:error 2021-12-20 14:58:45: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2021-12-20 14:58:45: Failed to start zigbee
Zigbee2MQTT:error 2021-12-20 14:58:45: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
Zigbee2MQTT:error 2021-12-20 14:58:45: Exiting...
Zigbee2MQTT:error 2021-12-20 14:58:45: Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0'
[14:58:45] INFO: Handing over control to Zigbee2mqtt Core ...
> node index.js
Zigbee2MQTT:warn 2021-12-20 14:58:54: `permit_join` set to `true` in configuration.yaml.
Zigbee2MQTT:warn 2021-12-20 14:58:54: Allowing new devices to join.
Zigbee2MQTT:warn 2021-12-20 14:58:54: Set `permit_join` to `false` once you joined all devices.
Zigbee2MQTT:warn 2021-12-20 14:58:54: Using experimental new availability feature
[15:06:37] INFO: Handing over control to Zigbee2mqtt Core ...
> node index.js
Zigbee2MQTT:warn 2021-12-20 15:06:44: `permit_join` set to `true` in configuration.yaml.
Zigbee2MQTT:warn 2021-12-20 15:06:44: Allowing new devices to join.
Zigbee2MQTT:warn 2021-12-20 15:06:44: Set `permit_join` to `false` once you joined all devices.
Zigbee2MQTT:warn 2021-12-20 15:06:44: Using experimental new availability feature
