Z2MQTT write 502 Bad gateway after 12-2022
Hi, after 12-22 update yesterday I have Z2MQT unaccesible, there is 502 bad gateway text only. Data from zigbee devices are unaccesible. No errors in logs. All system worked before update.
Conf: HA is virtual server (not Docker) on Synology 7. Zigbee gateway ethernet connected Lidl/Tuya hacked.
Is any specific MQTT change in update? Any tip for solution? Thx.
:thinking:
Restarting Mosquitto broker
Are you using external converter? Try disabling it if you are using it and restart z2m
sure, no change
IP wifi/ethernet box, cable connected. No change.
My configuration:
VM
Home Assistant 2022.12.1
Supervisor 2022.11.2
Operating System 9.3
Mosquitto broker - Current version: 6.1.3
logins:
  - username: mqtt
    password: mqtt
require_certificate: false
certfile: fullchain.pem
keyfile: privkey.pem
customize:
  active: false
  folder: mosquitto
Zigbee2MQTT Current version: 1.28.4-1 - ConBee
data_path: /config/zigbee2mqtt
socat:
  enabled: false
  master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
  slave: tcp-listen:8486,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
  options: "-d -d"
  log: false
mqtt:
  base_topic: zigbee2mqtt
  server: mqtt://core-mosquitto
  user: mqtt
  password: mqtt
serial:
  port: >-
    /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DExxxxx
  adapter: deconz
external_converters: []
devices: devices.yaml
groups: groups.yaml
homeassistant: true
permit_join: false
advanced:
  log_level: warn
  pan_id: 6754
  channel: 11
  network_key:
    - 1
    - 3
    - xx
    - 7
    - xx
    - 11
    - 13
    - xx
    - 0
    - 2
    - 4
    - 6
    - 8
    - 10
    - 12
    - xx
  availability_blocklist: []
  availability_passlist: []
  elapsed: true
  last_seen: ISO_8601_local
device_options: {}
blocklist: []
passlist: []
queue: {}
frontend:
  port: 8099
experimental: {}
availability: false
You need to be looking at the z2m logs to see why it isn’t starting.
