Hello All,
When I try to install the integration, I do not see zabbix in the integration list. I used the document Zabbix - Home Assistant to configure on HA side and also created a Host using the template described in this document. Though I am not sure if things are working correctly as there is no way for me to check.
Any help on this subject will be appreciated. Thanks in advance.
