Hello Home Assistant Community,
I would like to introduce a Zabbix template that simplifies monitoring your Home Assistant environment. This template is designed for Zabbix 7.0 (or higher) and provides practical features for comprehensive monitoring.
Features
This template monitors the following:
Item | Description |
Automations | Monitors active automations in Home Assistant. Helps detect faulty or blocked automations. |
Battery Status | Checks the battery level of battery-powered devices, such as sensors or remotes. Alerts on low battery. |
Cameras | Monitors the status of cameras integrated with Home Assistant, including optional reachability and video streams. |
Contact Sensors | Tracks the state of contact sensors (e.g., doors and windows). |
Firmware Updates | Checks for available firmware updates for connected devices. |
Humidity Sensors | Monitors current humidity levels in supervised rooms. |
Temperature Sensors | Tracks temperature values from Home Assistant. |
Air Pressure | Monitors the current air pressure readings from Home Assistant sensors. Useful for weather monitoring and trend analysis. |
Person Zone Assignment | Tracks which zone (e.g., Home, Work) a person is currently assigned to, based on GPS location. |
Zone Radius | Monitors the radius size of configured zones in Home Assistant. Helps ensure accurate geofencing. |
Longitude | Displays the longitude of a configured zone. Useful for precise geolocation settings. |
Latitude | Displays the latitude of a configured zone. Useful for precise geolocation settings. |
Home Assistant Updates | Monitors the Home Assistant version. Sends notifications when updates are available. |
Power Consumption | Tracks the energy usage of connected devices (e.g., smart plugs). Useful for analyzing power consumption. |
Weather Forecast | Integrates weather forecast data from Home Assistant, including temperature, rain probability, and wind speed. |
Zigbee Link Quality | Monitors the signal quality of Zigbee devices. Helps identify connection issues or interference. |
Occupancy | Tracks whether a room or area is currently occupied, using motion or presence sensors. |
Illuminance | Monitors the light level (lux) in a room or area, useful for automations like adjusting lights. |
PM2.5 | Tracks fine particulate matter (PM2.5) concentration in the air, important for air quality monitoring. |
VOC | Monitors volatile organic compounds (VOC) levels, helping to ensure good indoor air quality. |
- Supports Home Assistant updates.
- Includes macros for easy API token and URL configuration.
Whatβs Included
- A ready-to-import Zabbix Template (
.yaml
file). - Predefined macros for easy setup:
{$API.TOKEN}
: Your Home Assistant API token.{$HA.URL}
: The URL of your Home Assistant instance.
Requirements
- Zabbix Server version 7.0 or higher.
- Home Assistant API token.
Setup
- Download the template from the GitHub repository: [GitHub Link].
- Import the
.yaml
file into Zabbix. - Adjust the macros (
{$API.TOKEN}
and{$HA.URL}
). - Link the template to your Home Assistant host in Zabbix.
