ZAMG - Weather Sensor - unkown station?
dont get any data from ZAMG integration…
Configured ZAMG station_id (11090) is not a known station
4:47:25 PM – zamg (ERROR)
Configured ZAMG station_id (11042) is not a known station
but both are correct acording to ZAMG website.
Any ideas?
thx
Same here. Only option for me is to rely on the default configuration.
If I try to specify name or station_id, I don’t get the weather or sensor entity anymore…
I had the same problem. The documentation in https://www.home-assistant.io/integrations/zamg/ is linking to the wrong CSV file.
The source code is pulling this file:
https://www.zamg.ac.at/cms/en/documents/climate/doc_metnetwork/zamg-observation-points
br
same problem here… someone can solve it?
2021-01-31 12:34:40 ERROR (SyncWorker_0) [homeassistant.components.zamg.sensor] Configured ZAMG station_id (11059) is not a known station
Use a station id from the second link in the post above yours.
with station_id 4905 instead of 11059 its the same error.
ERROR (SyncWorker_6) [homeassistant.components.zamg.sensor] Configured ZAMG station_id (4905) is not a known station
obviously it is working again with the station number in the liked file: e.g. with 11150 for Salzburg
Unfortunately, the number of stations is rather limited and not very useful if you don’t live in one of the cities.
