ZB bridge tasmotized and need to create node red config to interact with the switch back and forth
Current setup: zb bridge with one sub device(snonof switch), Home assistant, MQTT server and node red.
I have flashed tasmota firmware on the snonoff zigbee bridge with one sub device (a sonoff switch)and want to configure node-red to be able to interact to and from from the device and also the UI button.
Currently able to achieve a flow from UI toggle switch and the hardware relay function fine.
But when I use node red to toggle the hardware get the signal but UI of the HA doenst change.
Hence I can say I am able to activate switch from both UI and node red. Issues is when switch on/off from the node red side i see no change in the UI.
anyone here can help?
