Got this notification about a month ago:
The device in question is a sonoff zbmini. I had no idea OTA updates were possible over zigbee, and I even have a few other zbmini devices but only this one prompts for an update.
However, the update always fails. And the logs are not very helpful:
Logger: homeassistant.components.websocket_api.http.connection
Source: components/websocket_api/commands.py:240
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 15:52:13 (1 occurrences)
Last logged: 15:52:13
[546976940224] Update was not successful - result: <Status.FAILURE: 1>
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 240, in handle_call_service
response = await hass.services.async_call(
File "/usr/src/homeassistant/homeassistant/core.py", line 2279, in async_call
response_data = await coro
File "/usr/src/homeassistant/homeassistant/core.py", line 2316, in _execute_service
return await target(service_call)
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 892, in entity_service_call
single_response = await _handle_entity_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 962, in _handle_entity_call
result = await task
File "/usr/src/homeassistant/homeassistant/components/update/__init__.py", line 161, in async_install
await entity.async_install_with_progress(version, backup)
File "/usr/src/homeassistant/homeassistant/components/update/__init__.py", line 465, in async_install_with_progress
await self.async_install(version, backup)
File "/usr/src/homeassistant/homeassistant/components/zha/update.py", line 177, in async_install
raise HomeAssistantError(f"Update was not successful - result: {results}")
homeassistant.exceptions.HomeAssistantError: Update was not successful - result: <Status.FAILURE: 1>
What can be done?
