ZB/ZW confusion
Running HAOS on an unRAID VM. Got the Sonoff USB Dongle Plus for Zigbee and have a handful of devices. Then pickedup the Zooz ZST10 for ZWave. Could only get it working by running the zwave-js-ui as a separate docker on the unRAID box. Do not have an ZW devices, but looking to get a ZW smart lock.
Just had an unRAID OS update and when everything came back, ran into a problem with passing the Sonoff to HAOS. Both the Zooz and Sonoff show up in unRAID with the exact same description (hoping the pic came through). This is causing the passing of the ZB to HAOS to fail. The only way to make this work is to disconnect the Zooz, pass the Sonoff to HAOS and reconnect the Zooz.
Any meaningful explanation? Am I missing something? Thx in adv.
What does ls -l /dev/serial/by-id tell you?
So that’s the ZW stick.
This is what the VM config shows for USB devices:
And the ZB stick is plugged in and is in fact recognized by HAOS.
Just not sure where in /dev the ZW stick shows.
