Has anyone been able to get Sonoff’s ZB Dongle-E working? I’ve tried ubuntu with virutal box, debian with supervised install and now Windows 10 on virtualbox and I can not get Zigbee2MQTT to work with this dongle.
I get
[17:09:14] INFO: Preparing to start...
[17:09:14] INFO: Socat not enabled
[17:09:15] INFO: Starting Zigbee2MQTT...
Zigbee2MQTT:info 2023-08-27 17:09:17: Logging to console and directory: '/config/zigbee2mqtt/log/2023-08-27.17-09-17' filename: log.txt
Zigbee2MQTT:info 2023-08-27 17:09:17: Starting Zigbee2MQTT version 1.32.2 (commit #unknown)
Zigbee2MQTT:info 2023-08-27 17:09:17: Starting zigbee-herdsman (0.17.2)
Error: Reset error: Error: {"sequence":-1} after 10000ms
at /app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/uart.ts:299:23
at Queue.executeNext (/app/node_modules/zigbee-herdsman/src/utils/queue.ts:32:32)
I’ve flashed it with
ncp-uart-sw_6.10.3_115200.gbl and ncp-uart-sw_7.3.1.0_115200.gbl
/config/zigbee2mqtt
enabled: false
master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
options: "-d -d"
log: false
mqtt:
server: mqtt://core-mosquitto:1883
user:user
password: password
serial
port: >-
/dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20230505100038-if00
adapter: ezsp
