I’m planning to buy some of the new IKEA Matter over Thread devices (starting with TIMMERFLOTTE, MYGGBETT and ALPSTUGA - more will follow) and want to integrate them into Home Assistant.
Thanks!
Just curious - how do the bulbs, bilresa, TIMMERFLOTTE, etc get their firmware directly - through the IKEA Android App or? I mean if i dont have the DIRIGERA bridge.
There are lots of posts discussing Thread, Matter, and the new IKEA devices, just use the forum’s search function. My impression is, if you have a simple network setup (no VLANs and whatsoever) and just one thread border router (e. g. by using the ZBT-1 or ZBT-2), everything is running out of the box if you follow the instructions.
Hard to say, because it is really a question about how much support and updating the TBRs get. HA had been slacking for a bit, so DIRIGERA was probably a bit ahead before that, but now HA have sprung into gear and have updated the OTBR addon and Matter server, so now they are ahead.
That depends on IKEA. I have Onvis S4 smart plugs and they released the initial firmware on the CSA DCL and then had a convoluted update process that required an Apple Matter hub device (which I did not have for the following ones) and that was a BIG mess and annoyance and I dissed them on every internet site I could find that reviewed the smart plug. They have published their latest firmware on the CSA DCL and HA have updated it without a hitch.
My guess is that IKEA is publishing over CSA DCL, but someone with an IKEA device that needs an update will have to confirm that.
I think it is quite common with a firm releasing for a new technology for the first time and it will be better for the next devices, but new versions of existing ones and new device types.
Luckily IKEA is pretty good at costumer service in such a situation, so I guess it is no problem to return them to a warehouse and get new ones.
If they publish the firmware on the CSA DCL, then HA and any other TBR that use CSA DCL will be able to update them.
Sounds like both IKEAs thread border router and the ZBT-2 is good products, and the issues that was before with the HA slacking a bit is not an issue anymore.
So i guess it comes down to, what device i can get the fastest
I recently installed a ZBT-2, Matter and OTBR. The first thing I installed were 2 alpstugas, and in their entries under devices and services indicated the FW version and that there was an update available. Clicked to update each and they updated. No other hub, etc… I added the alpstugas via the HA mobile app on my iPad.
Just a comment that Onvis S4 smart plugs don’t play nicely with IKEA Thread devices. Everything is updated with the latest firmware as of March 2026, but none of my IKEA TIMMERFLOTTE or BILRESA devices will use an S4 as a Thread repeater. No amount of power cycling or resetting seems to help. I currently blame the S4 devices, but that’s just an unproven theory.
UPDATE 2026-04-21: I was able to convince these devices to use a nearby S4 as a repeater. It took quite a bit of fiddling with the devices. I removed batteries, did a factory reset, and then paired them to my Thread network while they were in very close proximity to the S4. That last step seems to be the most important; the IKEA devices seem to latch onto whatever Thread router was nearby when they are first provisioned, and they can be very reluctant to switch to a different repeater when you move them around the house.
I have 2 Alpstugas, 2 Inovelli fan switches and an Eve energy outlet in the middle tying it all together in the physical center. My interpretation of the Thread mesh diagram is that the alpstugas are faithfully participating as Thread mesh devices.
To your point, my experience with Thread so far is that because of the multi-big-vendor interpretations / implementations, we’re all “unproven theorists” for some time to come.
