ZBT-2 with a ZWA-2
I have a home assistant green with a zwa-2 and would like to add Zigbee because of the light bulbs.
  1. Can both the ZWA-2 and ZBT-2 coexist without issue connected to HA Green?
  2. Do I need to use 2.4ghz?
Can they coexist?
Yes, as long as there’s another USB port for the ZBT-2 to plu into.
Do you need to use 2,4Ghz?
You don’t have a choice. the current Zigbee standard uses the 2.4Ghz spectrum. A future standard (more than a year away from seeing commercial products) will allow operation in the sub-Ghz range.
