I would like some advice, I am looking at getting a Temperature Sensor so that I can monitor the temperature in one of my rooms, but reading the spec on it, it is saying that I will need a Zigbee hub.
my question is: if I have a USB d Phoscon ConBee II The universal Zigbee USB gateway coordinator already and set up then will this do the same job as the zigbee hub the specs are talking about ?
the sensor I am looking at is Aqara WSDCGQ11LM from amazon and the second question I have: will it work with Home Assistant ?
This work great as I have a few. Just recently started playing with the Bluetooth switchbot and govee ones as they have a display for about the same price.
Just to clarify, “Zigbee hub” is marketing speak for Zigbee Coordinator. The Aqara range I believe are well supported by ZHA so you should be good to go.
