Zemismart M1 vs M6 vs M1 Pro – Which Hub Should Home Assistant Users Choose?
The rise of Matter has significantly simplified smart home integration. Instead of relying on multiple vendor-specific gateways and integrations, users can now connect a wider range of devices through a common standard.
For Home Assistant users, this has made setup easier, improved interoperability, and expanded device compatibility across Zigbee, Matter, and Thread ecosystems.
With more Matter-enabled hubs now available from Zemismart, including the M1, M6, and M1 Pro, many users are now evaluating which model best fits their smart home setup.
This post aims to break down the differences and help users make a practical choice.
Quick Comparison
Feature M1 M6 M1 Pro
Zigbee Hub :white_check_mark: :white_check_mark: :white_check_mark:
Matter Bridge :white_check_mark: :white_check_mark: :white_check_mark:
Matter Controller :white_check_mark: :cross_mark: :white_check_mark:
Thread Border Router :white_check_mark: :cross_mark: :white_check_mark:
External Zigbee Antenna :cross_mark: :white_check_mark: :white_check_mark:
IR Remote Control :cross_mark: :cross_mark: :white_check_mark:
Ethernet :white_check_mark: :white_check_mark: :white_check_mark:
Wi-Fi Connection :cross_mark: :cross_mark: :white_check_mark:
Home Assistant Integration :white_check_mark: :white_check_mark: :white_check_mark:
M1 – Best for Matter + Thread Beginners
The M1 was Zemismart's first hub combining:
  • Zigbee Hub
  • Matter Bridge
  • Matter Controller
  • Thread Border Router
For users who want to start building a Matter ecosystem and use Thread devices, the M1 is still a very capable choice.
Typical use cases:
  • Matter-over-Thread sensors
  • Thread smart plugs
  • Apple Home users
  • Google Home users
  • Home Assistant users who want an additional Thread Border Router
If your focus is Matter and Thread compatibility rather than Zigbee range, the M1 remains a solid option.
M6 – Best for Large Zigbee Networks
The M6 was designed with a different goal.
Compared with the M1, it adds an external high-gain Zigbee antenna that significantly improves Zigbee coverage and stability, especially in larger homes.
However, the M6 removes:
  • Matter Controller
  • Thread Border Router functionality
This means it is primarily a Zigbee-to-Matter bridge rather than a full Matter infrastructure device.
Typical use cases:
  • 100+ Zigbee devices
  • Large houses
  • Multi-floor installations
  • Users who already have Thread Border Routers (HomePod, Apple TV, Nest Hub, HA Yellow, etc.)
If your main goal is building a reliable Zigbee network, the M6 is often the better choice.
M1 Pro – The All-in-One Flagship
The M1 Pro combines the advantages of both previous models and adds several new features.
Key upgrades include:
  • Zigbee Hub
  • Matter Bridge
  • Matter Controller
  • External Zigbee Antenna
  • IR Blaster
  • Ethernet
  • Wi-Fi
It can bridge Zigbee and Thread devices into Matter ecosystems while also controlling traditional IR appliances such as TVs and air conditioners.
Typical use cases:
  • Mixed Zigbee + Thread environments
  • Apple Home users
  • Google Home users
  • SmartThings users
  • Users wanting one central hub for everything
For new installations in 2026, the M1 Pro is generally the most complete option.
Which One Should You Buy?
Choose M1 if:
  • You need Matter Controller + Thread Border Router
  • You have a small or medium Zigbee network
  • You want the most affordable Matter ecosystem entry point
Choose M6 if:
  • Zigbee coverage is your top priority
  • You already own Thread Border Routers
  • You have many Zigbee devices across a large home
Choose M1 Pro if:
  • You want one hub for Zigbee, Thread, Matter and IR devices
  • You want both Ethernet and Wi-Fi deployment options
  • You are starting a new smart home project and want maximum flexibility
Home Assistant Recommendation
For Home Assistant users:
I'd love to hear feedback from the community:
  • Which Zemismart hub are you currently using?
  • Have you compared M1 and M6 in a large Zigbee deployment?
  • How has M1 Pro performed in your Home Assistant setup?
With Home Assistant, you may not need a hub at all.
Why do I need you to gen up AI responses to questions neither I or many others have?
(I/we can do our own AI search...)
This sounds a lot like you are trying to slip in an Ad to me...
Can you start sharing Thread credentials and force tuya to fix their app GUI for 3rd party matter devices with your hubs? Because as a Matter controller, it’s bad for now (broken app GUI, buttons not supported, etc.)
example: Tapo Smart Temperature & Humidity Sensors - Tuya Developer Forum
Thanks for the feedback. We’ll try to if we have opportunity to forward the Thread credential sharing request and the Tuya app compatibility issues to our technical team for further review.
